Lisp modification - export polyline vertices (original by Tharwat)
Radu Iordache
Hello everybody! I made some modification to a lisp of @Tharwat found on this forum (thank you Tharwat!). The modifications I made are: to add a number before each pair of coordinates (starting with a chosen number) and also to save the file automatically near the DWG with some suffix (not to open a "save as" window).
I would be grateful if anybody could help me with some new modifications:
1. To add 2 new lines at the end of the txt file: polyline area and polyline perimeter.
2. To add a column with the distance between the points
So now the output is
     1,Y,X
     2,Y,X
     n,Y,X
And I would like it to be:
     1,Y,X,32.76 *distance between 1 and 2
     2,Y,X,35.89 *distance between 2 and 3
     n,Y,X,50.65 *distance between n and 1
     Area=500
     Perimeter=200
Numbers are random. DWG should be saved for the lisp to work.
I am using ProgeCAD so some functions may not work (though 90% do) so the simplest solution (with the most basic functions) would be best.
Thank you in advance!
exppl.lsp
Edited by Radu Iordache
  • Thanks 1
According to posted *.lsp...
(defun c:exppl ( / ss n nr fl op )
  ;; Tharwat. 11.May.16	;;
  ;; Modified           ;;
  (vl-load-com)
  (if (= 0 (getvar (quote dwgtitled)))
    (alert "Please, save DWG and restart routine... Quitting...")
      (initget 6)
      (setq n (cond ( (getint "\nNumber of first point <1> : ") ) (1)))
      (princ "\nSelect polylines : ")
      (and
        (setq ss (ssget (list (cons 0 "LWPOLYLINE,POLYLINE") (cons -4 "&") (cons 70 1))))
        (setq fl (substr (getvar (quote dwgname)) 1 (- (strlen (getvar (quote dwgname))) 4)))
        (setq op (open (strcat (getvar (quote dwgprefix)) fl "_exppl.txt") "w"))
          ( (lambda ( i / sn p as pp )
              (while (setq sn (ssname ss (setq i (1+ i))))
                (if (not nr)
                  (setq nr n)
                (mapcar
                  (function (lambda ( x )
                    (and
                      (= (car x) 10)
                      (setq p (cdr x))
                      (if (setq as (assoc 10 (cdr (member x (entget sn)))))
                        (setq pp (cdr as))
                        (setq pp (cdr (assoc 10 (entget sn))))
                      (write-line (strcat (itoa nr) "," (rtos (cadr p) 2 3) "," (rtos (car p) 2 3) "," (rtos (distance p pp) 2 3)) op)
                      (setq nr (1+ nr))
                  (entget sn)
                (write-line (strcat "Area = " (rtos (vlax-curve-getarea sn) 2 3)) op)
                (write-line (strcat "Perimeter = " (rtos (vlax-curve-getdistatparam sn (vlax-curve-getendparam sn)) 2 3)) op)
                (write-line "" op)
            -1
          (close op)
HTH.
M.R.
Edited by marko_ribar
Something like this ?
(defun c:exppl (/ ss fl op)
  ;;	Author : Tharwat Al Choufi			;;
  ;; website: https://autolispprograms.wordpress.com	;;
  (initget 6)
  (or (setq nr (getint "\nNumber of first point <1>:"))
      (setq nr 1)
  (princ "\nSelect polyline:")
  (and
    (setq ss (ssget ":S" '((0 . "LWPOLYLINE,POLYLINE"))))
    (setq fl (substr (getvar "dwgname")
                     1
                     (- (strlen (getvar "dwgname")) 4)
    (setq op (open (strcat (getvar "dwgprefix") fl "_exppl.txt") "w"))
      ((lambda (i / sn p d)
           (mapcar
             '(lambda (x)
                (and (= (car x) 10)
                     (or (and p (setq d (distance p (setq p (cdr x)))))
                         (setq p (cdr x))
                     (write-line
                       (strcat (itoa nr)
                               (rtos (cadr p) 2 3)
                               (rtos (car p) 2 3)
                               (if d
                                 (strcat "," (rtos d 2 3))
                       op
                     (setq nr (1+ nr))
             (entget sn)
           (foreach itm (list (list "Perimeter = "
                                      sn
                              (list "Area = " (vlax-curve-getarea sn))
             (write-line (strcat (car itm) (rtos (cadr itm) 2 3)) op)
        -1
      (close op)
  (initget 6)
      (setq nr 1)
  (and
                     1
           (mapcar
             '(lambda (x)
                (and (= (car x) 10)
                         (setq p (cdr x))
                     (write-line
                       (strcat (itoa nr)
                               (rtos (cadr p) 2 3)
                               (rtos (car p) 2 3)
                               (if d
                       op
                     (setq nr (1+ nr))
             (entget sn)
                                      sn
        -1
      (close op)
Almost :)
The only issue is that the output looks like this:
50,379.803,241.522
51,379.803,444.244,202.722
52,237.184,444.244,142.618
53,237.184,241.522,202.722
Perimeter = 690.681
Area = 28911.901
The distance on line 2 should be on line 1. The one on line 3 should be on line 2 and so on. Then, the distance on last line should be the distance between last point and first point. In present output a distance is missing. I attach the test DWG from which I got the above output.
So it should look like this:
50,379.803,241.522,202.722
51,379.803,444.244,142.618
52,237.184,444.244,202.722
53,237.184,241.522,142.618
Perimeter = 690.681
Area = 28911.901
Thank you so much for your help, @Tharwat!
1.dwg
6 minutes ago, Radu Iordache said:
Almost :)
50,379.803,241.522
Perimeter = 690.681
Area = 28911.901
Perimeter = 690.681
Area = 28911.901
Have you tried my post...
It should allow multiple polylines selection... Only lack is that it's not applicable for arced segmented polylines...
Tschus...
M.R.
  • Thanks 1
(defun c:exppl ( / ss n fl op )
  ;; Modified           ;;
  (vl-load-com)
      (initget 6)
      (and
          ( (lambda ( i / nr sn p as pp )
                (setq nr n)
                (mapcar
                    (and
                      (= (car x) 10)
                      (setq p (cdr x))
                        (setq pp (cdr as))
                      (setq nr (1+ nr))
                  (entget sn)
                (write-line "" op)
            -1
          (close op)
Untested, though...
HTH.
M.R.
Yes, it works great!! First I tested in Autocad and it returned an error like "unable to get ObjectID. Now I tested in ProgeCAD and it's doing exactly what I wanted. Thank you so much @marko_ribar!
And the Alert about saving the DWG is priceless!
Tschus...
M.R.
@marko_ribar, after my reply above I tested some more and I found one issue. If I have more than 1 polyline, it starts numbering for each one with the same number. For example, if I input 50 as start number and I have 2 polylines, the output looks like this:
50,364.522,60.192,124.28
51,364.522,184.474,156.88
52,207.642,184.474,124.28
53,207.642,60.192,156.88
Area = 19497
Perimeter = 562.32
51,379.803,444.244,142.62
53,237.184,241.522,142.62
Area = 28912
Perimeter = 690.68
It should continue the numbering, second polyline being 54,55,56,57. Can it be solved? Thanks again so much!
@Radu Iordache Take out this line to fix the numbering. Ooops .. move it above the while loop :)
Edited by ronjonp
Here you go, the idea behind coding the program this way seems insane and different. :D
(defun c:exppl (/ ss fl op nr e a l)
  (initget 6)
  (or (setq nr (getint "\nNumber of first point <1> : "))
      (setq nr 1)
  (princ "\nSelect polylines :")
  (and
                     1
      ((lambda (i / g m p d)
         (while (setq e (ssname ss (setq i (1+ i))))
           (setq g (entget e)
                 a (assoc 10 g)
                 m (cdr (cddddr (member a g)))
                 g (append g (list a))
                 a (cdr a)
                 l nil
           (or l (setq l a))
           (mapcar
             '(lambda (x)
                (and (= (car x) 10)
                     (setq p (cdr x))
                     (write-line
                       (strcat (itoa nr) "," (rtos (cadr a) 2 3) "," (rtos (car a) 2 3) "," (rtos (distance a p) 2 3))
                       op
                     (setq nr (1+ nr)
                           a  p
             m
           (write-line
             (strcat (itoa nr) "," (rtos (cadr a) 2 3) "," (rtos (car a) 2 3) "," (rtos (distance a l) 2 3)) op
           (setq nr (1+ nr))
                                      e
                                      (vlax-curve-getendparam e)
                              (list "Area = " (vlax-curve-getarea e))
        -1
      (close op)
) (vl-load-com)
Edited by Tharwat
Does not work for me, it gives a bad argument type error if I remove it.
  (initget 6)
      (setq nr 1)
  (and
                     1
           (setq g (entget e)
                 a (assoc 10 g)
                 a (cdr a)
           (or l (setq l a))
           (mapcar
             '(lambda (x)
                (and (= (car x) 10)
                     (setq p (cdr x))
                     (write-line
                       op
                     (setq nr (1+ nr)
                           a  p
             m
           (write-line
           (setq nr (1+ nr))
                                      e
        -1
      (close op)
) (vl-load-com)
@Tharwat Later edit: something wrong happens with the distances starting with the second polyline. For example, these are 3 rectangles. I marked in red the wrong distances.
Perimeter = 690.681
Area = 28911.901
54,419.282,491.983,116.88
55,419.282,608.862,133.15
56,286.127,608.862,116.88
57,286.127,491.983,267.41
Perimeter = 500.068
Area = 15563.048
58,204.097,267.437,431.93
59,204.097,699.368,37.49
60,166.609,699.368,431.93
61,166.609,267.437,214.76
Perimeter = 938.837
Area = 16192.325
Initial reply:
Thanks a lot, it works great!
2 hours ago, Radu Iordache said:
Initial reply:
You're welcome.
I didn't know you needed continuation of vertices between polylines... I've mod. my version, you can test it - should work...
@Radu Iordache There was one minor issue if you select more than one polylne then the outcome would mix up with the other polylines' data so I have revised the codes above accordingly.
