Add/Remove entity in a group .... with VL-xxx
X11start
I use groups to verify that I have selected all blocks that make up a single precast panel. Would it be possible to modify lisp GRP
, to also add/remove elements to an existing group? In this moment I use (command "_Group"...) but I would prefer to use the VL-xxx commands but of these I am not expert.
Bricscad has a dcl that opens and has options like add and delete. Was thinking wether there is a variible to set so Acad does the same rather just select.
I know that there aren't many people who use groups, but I need them to understand if I have selected all the blocks of a precasted panel.. or if I've wiggled some. For this I need to be able to make a lisp in which I add and remove from the group. I use GtarCad Thanks Bigal
That was me on Sunday - will see if I get a chance to look at this later but a holiday last week and the e-mails are going a little busy just now
