Multileader
Deepak Raman
Hi all,
Clicking on multileader, it starts with Mtext window instead of the arrow (leader) which is annoying; how to change back to original sequence? although I don't remember changing anything for the MLEADER style anytime.. any info appreciated..!! thanks in advance..
Check these system variables:
PICKFIRST should be 1
DBLCLKEDIT should be on
noun/verb selection should be on
Check your UI behavior, default double-click should be, well, whatever you were doing, instead of TEXTEDIT.
If that doesn't help, please provide more information.
Welcome to the forum!
Hi there.. thank you for your time and response. But problem not solved, though i checked PICKFIRST-1, DBLCLKEDIT-on ... Pls check the video attached, waiting for your further valuable advice..
Try looking at your commandline, the option is there to set it back to Leader Arrowhead first or hit the down arrow on the keyboard to bring up options.
