Purging the whole propertyset definitions using .net api
Hello
I am trying imitate the purge action availble in Civil3d 2022 by right clicking on the property set definitions which removes everything.
I need to do this using C#.
The code that is short and clear is the next code found somewhere, but complains about the function not finding PropertySetDefinitionCollection
using (var db = HostApplicationServices.WorkingDatabase)
                // Get the propertyset definition collection
                var psdColl = db.PropertySetDefinitionCollection; // so it can't find PropertySetDefinitionCollection, it does not exist according to visual studio
                // Purge all the propertyset definitions
                psdColl.Purge();
Am I missing something? All dll's should be added: accoremgd.dll, acdbmgd.dll, acmgd.dll, AecBaseMgd.dll, AeccDbMgd.dll.
These dll's are in both locations available:
1) C:\Program Files\Autodesk\AutoCAD 2022
2) C:\Program Files\Autodesk\AutoCAD 2022\C3D
Does it matter which one you pick?
Thank you in advance!
I don't work in C# but do stuff in CIV3D so maybe  have you declared DB as the correct CIV3D database it varies for each CIV3D version.
