bustr Posted April 19, 2023 Share Posted April 19, 2023 I'm trying to use this script but the space in "pdf_solid fills" is being read as a carriage return. Is there a way to deal with this? -LAYER off pdf_solid fills LIMITS 0,0 11,17 Command: _SCRIPT Enter script file name <O:\Motiva\2022\22022020.00 - USMF 00454 SRU2 & 3 TGTU1 IPF Upgr (DE)\Working\Instr-Elect\05_Drawings\01_Working\SHARED SmartPlant Instrumentation\214SC-13 TB12-DEMO.scr>: "\\olson-fs01\users\mgooch\DWG_BACKUP\TGTU1_CHECK\STRIP_PREPARATION_SCRIPT.SCR" Command: -LAYER Current layer: "RED LINE" Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: off Enter name list of layer(s) to turn off or <select objects>: pdf_solid No matching layer names found. Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: fills Invalid option keyword. Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted April 19, 2023 Share Posted April 19, 2023 Have you tried putting the layer name in quotes? Use "pdf_solid fills" in the script instead of the literal name. If that doesn't work, check back with us. 2 Quote Link to comment Share on other sites More sharing options...
bustr Posted April 19, 2023 Author Share Posted April 19, 2023 Thanks. That worked. Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 17, 2023 Share Posted June 17, 2023 I think with scripts just like DCL files you have to put a slash in front of the quote for it to register properly. (write-line " : edit_box {label = \"CASE TYPE\"; key = \"case\"; alignment = centered; edit_width = 50; allow_accept = true;}" fo) would make a line in dcl file : edit_box {label = "CASE TYPE"; key = "case"; alignment = centered; edit_width = 50; allow_accept = true;} Quote Link to comment Share on other sites More sharing options...
