(defun c:ExportAngleToExcel (/ excel-app excel-wb excel-ws angle p1 p2 row-num)
  ;; Set the existing Excel file path
  (setq file-path "C:\Path\To\Your\File.xlsx")
  ;; Create an instance of Excel application
  (setq excel-app (vl-catch-all-apply 'vlax-get-or-create-object '("Excel.Application")))
  ;; Open the existing workbook
  (setq excel-wb (vl-catch-all-apply 'vlax-invoke-method excel-app 'Workbooks 'Open file-path))
  (setq excel-ws (vl-catch-all-apply 'vlax-get-property excel-wb 'ActiveSheet))
  ;; Find the last used row in the Excel sheet
  (setq row-num (+ (vl-catch-all-apply 'vlax-get-property excel-ws 'UsedRange.Row)
                   (vl-catch-all-apply 'vlax-get-property excel-ws 'UsedRange.Rows)
                   1))
  ;; Loop to get multiple angles
  (repeat 5 ; Change the number according to your requirement
    ;; Prompt the user to select the first point
    (setq p1 (getpoint "\nSelect first point: "))
    ;; Prompt the user to select the second point
    (setq p2 (getpoint p1 "\nSelect second point: "))
    ;; Calculate the angle between the two points
    (setq angle (rtos (angtos (angle p1 p2)) 2))
    ;; Write the angle value to Excel
    (vl-catch-all-apply 'vlax-put-property (vl-catch-all-apply 'vlax-get-property excel-ws 'Cells row-num 1) 'Value (strcat "Angle " (itoa (1+ row-num))))
    (vl-catch-all-apply 'vlax-put-property (vl-catch-all-apply 'vlax-get-property excel-ws 'Cells row-num 2) 'Value angle)
    ;; Increment the row number
    (setq row-num (1+ row-num))
  ;; Activate Excel application to make it visible
  (vl-catch-all-apply 'vlax-invoke-method excel-app 'Activate)
  ;; Save and close the Excel workbook
  (vl-catch-all-apply 'vlax-invoke-method excel-wb 'Save)
  ;; Close the Excel workbook without saving changes
  (vl-catch-all-apply 'vlax-invoke-method excel-wb 'Close :vlax-false)
  ;; Quit Excel application
  (vl-catch-all-apply 'vlax-invoke-method excel-app 'Quit)
  ;; Release COM objects
  (vlax-release-object excel-ws)
  (vlax-release-object excel-wb)
  (vlax-release-object excel-app)
  ;; Clear any unreferenced symbols
  (gc)
Try to change the path as follows:
This one C:\\Path\\To\\Your\\File.xlsx" or this one C:/Path/To/Your/File.xlsx"
