MUTHUKUMAR1983 Posted May 24, 2023 Share Posted May 24, 2023 (defun c:ExportAngleToExcel (/ excel-app excel-wb excel-ws angle p1 p2 row-num) ;; Set the existing Excel file path (setq file-path "C:\Path\To\Your\File.xlsx") ;; Create an instance of Excel application (setq excel-app (vl-catch-all-apply 'vlax-get-or-create-object '("Excel.Application"))) ;; Open the existing workbook (setq excel-wb (vl-catch-all-apply 'vlax-invoke-method excel-app 'Workbooks 'Open file-path)) (setq excel-ws (vl-catch-all-apply 'vlax-get-property excel-wb 'ActiveSheet)) ;; Find the last used row in the Excel sheet (setq row-num (+ (vl-catch-all-apply 'vlax-get-property excel-ws 'UsedRange.Row) (vl-catch-all-apply 'vlax-get-property excel-ws 'UsedRange.Rows) 1)) ;; Loop to get multiple angles (repeat 5 ; Change the number according to your requirement ;; Prompt the user to select the first point (setq p1 (getpoint "\nSelect first point: ")) ;; Prompt the user to select the second point (setq p2 (getpoint p1 "\nSelect second point: ")) ;; Calculate the angle between the two points (setq angle (rtos (angtos (angle p1 p2)) 2)) ;; Write the angle value to Excel (vl-catch-all-apply 'vlax-put-property (vl-catch-all-apply 'vlax-get-property excel-ws 'Cells row-num 1) 'Value (strcat "Angle " (itoa (1+ row-num)))) (vl-catch-all-apply 'vlax-put-property (vl-catch-all-apply 'vlax-get-property excel-ws 'Cells row-num 2) 'Value angle) ;; Increment the row number (setq row-num (1+ row-num)) ) ;; Activate Excel application to make it visible (vl-catch-all-apply 'vlax-invoke-method excel-app 'Activate) ;; Save and close the Excel workbook (vl-catch-all-apply 'vlax-invoke-method excel-wb 'Save) ;; Close the Excel workbook without saving changes (vl-catch-all-apply 'vlax-invoke-method excel-wb 'Close :vlax-false) ;; Quit Excel application (vl-catch-all-apply 'vlax-invoke-method excel-app 'Quit) ;; Release COM objects (vlax-release-object excel-ws) (vlax-release-object excel-wb) (vlax-release-object excel-app) ;; Clear any unreferenced symbols (gc) (princ) ) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 24, 2023 Share Posted May 24, 2023 Try to change the path as follows: This one C:\\Path\\To\\Your\\File.xlsx" or this one C:/Path/To/Your/File.xlsx" Quote Link to comment Share on other sites More sharing options...
