Split 1 Text into 2
barristann
Is it possible to split 1 text into 2 separate texts, based on character "-"?
For example, can I split VAR-259 into
    VAR
    -259
Thank you all.
Edited by barristann
As simple as follows:
(setq str "VAR-259")
(and (setq pos (vl-string-search "-" str))
     (setq pre (substr str 1 pos))     ;; = VAR
     (setq suf (substr str (+ pos 2))) ;; = 259
I'd go string to List, splits at every character '-' and you can make up the texts to suit from  that
