deano33 Posted July 14, 2023 Posted July 14, 2023 ACAD 2012 fatel error at start up - info centre using lots of resources and fails to load Any ideas why info centre doesn't load? Does this connect online? Can I disable this feature? Quote
deano33 Posted July 14, 2023 Author Posted July 14, 2023 if I control+alt+delete in tack manager info centre is using 49% of CPU and eventually crashes acad with fatal error. If I end the task autocad loads up immediately and is ok. Can/should I just disable info centre? Quote
SLW210 Posted July 14, 2023 Posted July 14, 2023 What are your computer and graphics card specifications? What Operating System? Did this just start happening? For InfoCenter Off ... Miscellaneous (manusoft.com) AcadInfoCenterOff.msi Quote
deano33 Posted July 19, 2023 Author Posted July 19, 2023 PC been fin for 4 years and problem just started over last 2-3 weeks. Windows 10 on Dell optiplus 3060 I5. Graphics - Intel UHD Graphics 630 + Nvidia Quadro P400 Quote
SLW210 Posted July 19, 2023 Posted July 19, 2023 My WAG would be a Windows 10 update. AutoCAD 2012 was from before Windows 10 and even Windows 8 IIRC. You may have to look at the combatibility mode, if you have Windows 7 available run a virtual Windows 7. There is also the Longbow solution. Quote
BIGAL Posted July 21, 2023 Posted July 21, 2023 Maybe look at Bricscad Lite as an upgrade has a lot more functions than your 2012 including Lisp and at a reasonable price. Quote
