ILoveMadoka Posted August 4, 2023 Posted August 4, 2023 I found and modified the code found here to create this (defun C:EE1 (/ ent obj new_str) ;;; Add (E) to the end of a string (vl-load-com) (if (and (setq ent (car (entsel "\nSelect text object: "))) (wcmatch (cdadr (entget ent)) "*TEXT*") (setq obj (vlax-ename->vla-object ent)) (setq new_str "(E)")) (progn (vla-put-textstring obj (strcat (vla-get-textstring obj) " " new_str)) (princ "\nText updated successfully.") ) (princ "\nInvalid selection or empty string.") ) (princ) ) which works on a single selected object. Not sure how to create the repeat loop to process a selection set of TEXT/MTEXT objects. Quote
marko_ribar Posted August 4, 2023 Posted August 4, 2023 (defun C:EE1 (/ ss i obj new_str) ;;; Add (E) to the end of a string (vl-load-com) (if (and (not (prompt "\nSelect text objects on unlocked layer(s) : ")) (setq ss (ssget "_:L" '((0 . "*TEXT*")))) (setq new_str "(E)")) (repeat (setq i (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (vla-put-textstring obj (strcat (vla-get-textstring obj) " " new_str)) (princ "\nText updated successfully.") ) (princ "\nInvalid selection or empty string.") ) (princ) ) Untested, but should work as desired... HTH., M.R. Quote
ILoveMadoka Posted August 7, 2023 Author Posted August 7, 2023 Works perfectly.. Thank you so VERY much!! Quote
