koshur Posted February 23, 2009 Share Posted February 23, 2009 1st problem Ive encountered is when booting acad 2008 under the users login i get an then after hitting OK on the first one. works fine when Admin is logged on. any help please .. 2nd problem i just solved :wink: please help out , i f you have any idea what might be wrong, thanks Quote Link to comment Share on other sites More sharing options...
CADgirl Posted February 23, 2009 Share Posted February 23, 2009 Can you post larger pictures of the dialog boxes? It's too small to read. Quote Link to comment Share on other sites More sharing options...
Strix Posted February 23, 2009 Share Posted February 23, 2009 ... and too fuzzy when I blew it up Quote Link to comment Share on other sites More sharing options...
koshur Posted February 23, 2009 Author Share Posted February 23, 2009 1st problem Ive encountered is when booting acad 2008 under the users login i get an unhanded exception e06d7363 (e06d7363h) at address 7c812aebh exception in c:\........autocad\2008\32\acrobatic.arx then (same root and error as above) pdfmcad.arx after hitting OK on the first one. works fine when Admin is logged on. but not when the user is ,could it be a permissions issue ??any help please .. 2nd problem i just solved :wink: please help out , i f you have any idea what might be wrong, thanks Quote Link to comment Share on other sites More sharing options...
Strix Posted February 23, 2009 Share Posted February 23, 2009 please don't post multiple threads for the same problem what solved the second problem - in case anybody else comes here with the same problem? Quote Link to comment Share on other sites More sharing options...
koshur Posted February 23, 2009 Author Share Posted February 23, 2009 please don't post multiple threads for the same problem what solved the second problem - in case anybody else comes here with the same problem? sorry for some reason when i left my computer without finishing my post it auto posted it and i was unaware till i finished the post. the second problem was just a wipe out issue that had to do with the clients drawing. i put the description of the 2 errors under the pictures they are pdf errors, so if anyone can please help me out with the 2 errors (pictures and descriptions) i would be grateful thanks Quote Link to comment Share on other sites More sharing options...
