Hi there,
I am working on a schoolproject and i want to use the Batch Attribute Editor from Lee Mac, but it doesnt work.
I am using Autocad 2024 LT, version 1.5 of the program.
I get the program loaded up and i can select right block and values etc, but when i select the drawings on which it has to apply , it does nothing. doesnt even give an error. i can click the Run button, but nothing happens.
Anyone knows what i am doing wrong? Or is autocad LT 2024 jsut not supported?
Or any other options to edit multiple attributes at the same time?
Best regards, Niek
Pretty sure the  code uses OBDX method this is not supported in the LT 2024 version, there are other functions as well not supported. So Lt 2024 lisp is not quite 100% the same as full Autocad.
You may be able to do a script to carry out the same function, opening a dwg making changes save and close. The script opens a dwg then loads a lisp set to auto run.
Edited by BIGAL
  • 3 weeks later...
I am using Autocad 2023, the Batch Attribute editor lisp is not working for me. Does not give any error, but its stopped after opening one drawing.
Edited by Sourabh
