how to merge intersection pt & inside of area pt
exceed
now I'm making a routine like wmfout basic command,
but I ran into a problem.
The blue color at the bottom of the above gif is shifted to the right because it comes from a part that is out of range.
I already know how to find a list of points inside an object boundary.
but I want to know how to merge it with its intersection into a list of points in the correct order.
Since polylines and splines cannot predict the number of points and can be intersections several times...
so, I want the point list of the part highlighted in red in the picture below.
or
Thanks for reading.
Edited by exceed
Bpoly will do something close, to 1st image, note the single line sticking in will be ignored. The only way to make that work maybe is to make it a rectang with a width of 0.000000001
  • 7 months later...
(defun c:XDTB_DWGCUT (/ dynpt e lastpnt myerr olderr pts ss ss1 tf)
  (defun _callback (dynpt)
    (xdrx_entity_move ss lastpnt dynpt)
    (setq lastpnt dynpt)
  (defun _move (ss)
    (setq lastpnt (trans (xd::geom:get9pt ss 5)1 0))
    (xdrx_pointmonitor "_callback" ss)
    (initget 1)
    (getpoint (xdrx-string-multilanguage "\n插入点:""\nInsert Point:"))
    (xdrx_pointmonitor)
  (defun myerr (msg)
    (princ "\n*cancel")
    (xdrx_end)
    (vl-cmdf ".undo" 1)
    (setq *error* olderr)
  (xdrx_begin)
  (setq olderr *error*)
  (setq *error* myerr)
  (setq pts nil)
  (if (setq e (car (xdrx_entsel
                     (xdrx-string-multilanguage "\n请拾取裁剪边界<退出>:""\nPlease pick the cropping boundary <Exit>:")
                     '((0 . "lwpolyline,circle,ellipse,spline"))
    (progn (setq tf (xdrx-document-safezoom e))
           (setq pts (xdrx_getsamplept e)
                 ss  (ssget "cp" (xd::pnts:wcs2ucs pts))
           (if (setq ss1 (xdrx_geom_clipboundary ss e t t))
             (progn (if tf
                      (xdrx_document_zoomprevious)
                    (ssadd e ss1)
                    (_move ss1)
  (xdrx_end)
[XDrX-PlugIn(83)] DWG cutting (theswamp.org)
https://www.theswamp.org/index.php?topic=59019.0
  • Like 2
