CADWORKER Posted September 20 Share Posted September 20 Hi, I am looking for a lisp to move the arrowhead of the leader to the nearest point. There are multiple points and leaders which has to be adjusted. Thanks.Arrow and Points.dwg Quote Link to comment Share on other sites More sharing options...
Tsuky Posted September 21 Share Posted September 21 Hi, A start with your drawing (defun c:FOO ( / ss n dxf_ent pt ss_c i nw_pt a d) (setq ss (ssget "_X" '((0 . "LEADER")))) (cond (ss (repeat (setq n (sslength ss)) (setq dxf_ent (entget (ssname ss (setq n (1- n)))) pt (cdr (assoc 10 dxf_ent)) ) (cond ((setq ss_c (ssget "_C" (mapcar '- pt '(0.5 0.5 0.0)) (mapcar '+ pt '(0.5 0.5 0.0)) '((0 . "INSERT,POINT")))) (repeat (setq i (sslength ss_c)) (setq nw_pt (cdr (assoc 10 (entget (ssname ss_c (setq i (1- i))))))) (cond ((> (cadr nw_pt) (cadr pt)) (setq a (angle pt nw_pt) d (distance pt nw_pt) ) (foreach e dxf_ent (if (eq (car e) 10) (setq dxf_ent (subst (cons 10 (polar (cdr e) a d)) e dxf_ent)) ) ) (entmod dxf_ent) ) ) ) ) ) ) ) ) (prin1) ) Quote Link to comment Share on other sites More sharing options...
CADWORKER Posted September 21 Author Share Posted September 21 Tsuky Thanks you, This is excellent. Quote Link to comment Share on other sites More sharing options...
