malche Posted February 24, 2009 Posted February 24, 2009 I want to use a 3d model from 3dsMax in AutoCAD, and I want to use the same view angle. how can I do it? Thanx Quote
Cad64 Posted February 24, 2009 Posted February 24, 2009 You can take lights and cameras from Autocad to Max, because Max can Import the .dwg format, but you can't take them from Max to Autocad because Autocad can't Import the .max format. Why don't you just render in Max? Quote
malche Posted February 24, 2009 Author Posted February 24, 2009 If I take the camera from Autocad, Will the view in Max be exactly the same as AutoCAD? I must use AutoCAD to plot some 2d drafting of the same model. Quote
Cad64 Posted February 25, 2009 Posted February 25, 2009 Yes, if you Import your Autocad file into Max the Autocad camera view will be the same. Just make sure you check the option to "Include Views and Cameras" in the Import Options dialog. Quote
