Good morning guys
I need help accessing fields on a website.
I need to access the website below, fill in a search field, click on search and get the result and save a string.
https://buscacepinter.correios.com.br/app/endereco/index.php
Example text for search:  Avenida Ampélio Gazzetta
So far I have only been able to open the website, but after that I am unable to access the fields.
via execel/vba, I haven't found a way yet with autolilsp.
thanks for the help.
afaik not all sites can do that
since there is no website that simply uploads a .txt file to its address, ( https://www.cadtutor.net/forum/topic/75809-read-text-file-from-a-server-on-the-internet/ )
so, almost case, to do something like that, target website have to support API. ( https://en.wikipedia.org/wiki/API  )
if target website support an API, you can access like this link ( https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/make-an-api-call-with-autolisp-visuallisp/td-p/9083202 )
or this link ( https://www.cadtutor.net/forum/topic/56527-connect-to-web-server-via-lisp/ )
  • 3 weeks later...
