Has anyone a lisp for extacting y values
coombsie11
Hello.
I am looking for a lisp routine that will make adding levels to section drawings much easier. I know that they exist, as I have come across one in the past.
Once I have set a datum to a specific level, using the UCS in AutoCad I would then like to -
select/id a point, endp or nearest and have a predefined arrow block inserted at this point, with the Y value (level) given in predefined text next to it. Text and block in layer "LEVELS".
Its obviously so much quicker than IDing a point and then hand typing the text after and it eliminates user error too.
Can anyone help me please?:)
  • Replies 39
  • Lee Mac
    16
  • alanjt
    10
  • pontifex
    6
  • uddfl
    3
Posted Images
Why not use ordinate dimensions?
But here, have this LISP. It does not insert blocks but it's for updating existing text/blocks. Still pretty useful and can be easily extended to suit your exact needs.
(defun c:ue (); update elevation text
 (setq prev-osm (getvar "osmode"))
 (setq ypoint (cadr (getpoint "\nSpecify reference point for elevation: ")))
 (setq entname (car (nentsel)))
 (setq entlist (entget entname))
 (setq entlist (subst (cons 1 (rtos ypoint)) (assoc 1 entlist) entlist))
 (entupd entname)
 (entmod entlist)
I don't want to steal Lee Mac's glory, but here is one I wrote earlier. It draws a little triangle at the level point, and the level alongside.
;ELLEV is a programme to annotate levels of lines drawn for an elevation
(defun C:ELLEV (/ pt0 pt1 pt2 pt3 el elev x scale tsize)
          (if (= sc nil) (setq sc 100))
          (princ (strcat "\nEnter drawing scale <" (rtos sc 2 0) ">: "))
          (setq scale (getint))
          (if (= scale nil) (setq scale sc))
          (setq sc scale)
          (setq tsize (* 0.002 sc))
          (setvar "OSMODE" 1)   ; this sets Objectsnap to endpoint
          (while (setq pt0 (getpoint "\nPick elevation line point. . . . . ")
                x (car pt0)
                el (cadr pt0)
                elev (rtos el 2 3); set last figure for number of decimal places
                pt1 (list (+ x (* 0.002 sc)) (+ el (* 0.002 sc)))  ; text position
                pt2 (list (- x (* 0.001 sc)) (+ el (* 0.002 sc))) ;triangle position
                pt3 (list (+ x (* 0.001 sc)) (+ el (* 0.002 sc)))
           (setvar "OSMODE" 0)
           (command "LINE" pt0 pt2 pt3 "c")
           (command "TEXT" pt1 tsize "0" elev)   ;0.2 for 1 to 100
           (setvar "OSMODE" 1)
Thanks alot guys. I have tried the lsp and its just what I'm after. :D
Think that I will play around with it a little, so that it adds my arrow block and then I'll be adding levels like theres no tomorrow.:?
  • 1 year later...
Hi guys. I`ve been using this forum for a quite while now and it was very helpful so far. Especially when it comes to this lisp. And i was wondering, since i`m a newbie to lisp, dont know how to exactly change this - is there a way to add to every positive values "+" sign at the beginning of text. When it comes to negatives it works like a charm. And one other thing - how can i set default value of decimal places to 2?
Welcome to CADTutor :)
This should be faster and more robust :)
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:ellev [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] *error* Line Text P1 P2 PT PTW TSZE XW Y YW[b][color=RED])[/color][/b]
 [i][color=#990099];; Lee Mac  ~  01.03.10[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] *error* [b][color=RED]([/color][/b]msg[b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]wcmatch[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcase[/color][/b] msg[b][color=RED])[/color][/b] [b][color=#a52a2a]"*BREAK,*CANCEL*,*EXIT*"[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#a52a2a]"\n** Error: "[/color][/b] msg [b][color=#a52a2a]" **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Line [b][color=RED]([/color][/b]p1 p2[b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]entmakex[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#a52a2a]"LINE"[/color][/b][b][color=RED])[/color][/b]
                   [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]10[/color][/b] p1[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]11[/color][/b] p2[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Text [b][color=RED]([/color][/b]pt hgt str[b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]entmakex[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#a52a2a]"TEXT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]10[/color][/b]  pt[b][color=RED])[/color][/b]
                   [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]40[/color][/b] hgt[b][color=RED])[/color][/b]   [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b]  str[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] *scl [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] *scl [b][color=#009900]100[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] *scl [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]getint[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#a52a2a]"\nEnter Drawing Scale <"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]itoa[/color][/b] *scl[b][color=RED])[/color][/b] [b][color=#a52a2a]"> : "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]*scl[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tsze [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] [b][color=#009999]0.002[/color][/b] *scl[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]getpoint[/color][/b] [b][color=#a52a2a]"\nPick Elevation Line Point: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ptw [b][color=RED]([/color][/b][b][color=BLUE]trans[/color][/b] pt [b][color=#009900]1[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] xw [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ptw[b][color=RED])[/color][/b] yw [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] ptw[b][color=RED])[/color][/b] y [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] pt[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] p1 [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]-[/color][/b] xw [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] tsze [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] yw tsze[b][color=RED])[/color][/b] [b][color=#009999]0.[/color][/b][b][color=RED])[/color][/b]
         p2 [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] xw [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] tsze [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] yw tsze[b][color=RED])[/color][/b] [b][color=#009999]0.[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]line ptw x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] p1 p2[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b]line p1 p2[b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b]Text [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] xw [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] yw tsze[b][color=RED])[/color][/b] [b][color=#009999]0.[/color][/b][b][color=RED])[/color][/b] tsze [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<=[/color][/b] [b][color=#009900]0[/color][/b] y[b][color=RED])[/color][/b] [b][color=#a52a2a]"+"[/color][/b] [b][color=#a52a2a]""[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] y [b][color=#009900]2[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Thanks for quick reply Lee. The thing is - it doesn't work in local UCS. Is there a way to adjust it? :)
It should account for UCS other than World :unsure:
It seems that it doesn't. The other thing is that when i click at a point with integer value (0 for example in the attach.) , it doesnt put +0,00 as i was hoping it to do.
It is set to show three d.p. - the trailing zeros are affected by your Sys Var settings, not my code.
As for the UCS thing - the point was correct, just the elevation text was relative to WCS, not UCS. I have updated the original code to account for this.
Check the dimzin variable.
:ouch:Found it, my mistake. Sorry. Didn't realize it wasn't the code. I hope this isn't one of the stupid questions: can the code use curently used text style or it can only use the standard/default one? My text font in the drawings isn't the "Standard" one used as default by Autocad. Everything else works perfect! Thank You Lee :D
Certainly:
                   [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]40[/color][/b] hgt[b][color=RED])[/color][/b]   [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b]  str[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]7[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=DARKRED]'[/color][/b]TEXTSTYLE[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Glad the code works for you :)
Lee,
One other thing I realised, I promise :) While in the local UCS, can the text as well as the triangle automatically rotate to be parallel to the X axis just like it is when I'm in WCS? :oops:
