Hello. I am completely new to writing code so apologies if code looks bad.
I am trying to write a Lisp that would select 2 named blocks after thawing and turning on all layers.
The problem is I get stuck in the Select Blocks command after it selects the 2 blocks.
If I press Enter, it just exits without the 2 selected blocks
(defun c:myMacro ()
  ; Thaw all layers
  (command "._LAYTHW" "all")
  ; Turn on all layers
  (command "._LAYON" "all")
  ; Select Blocks named A1 and A2
  (setq ss (ssget "_X" '((0 . "INSERT") (2 . "A1,A2"))))
  (if ss
    (command "_SELECT" ss)
What exactly am I doing wrong here?
Edited by Colomon249
