Hi all,
i'm a beginner at Lisp programming .I started with the beginners Tutorials from Afralisp,  Kenny already has a LISP function in his tutorials that does what i want.
And already found some other LISP-Function that loops throught a selection set and prints the entity name (Thanks to Lee Mac).
There is a tutorual about Adding specific User data to an item.
https://www.afralisp.net/autolisp/tutorials/extended-entity-data-part-1.php
But i need to add these Userdata to all items in the model on a specific layer , the user data should be the actual modelname.
i modified the Script "entity List" Script  from Lee Mac, now it outputs only the entity names on my disired layer.
 (if (setq s (ssget "_X" '((8 . "desired Layer"))))
            (setq i 0
                  n (sslength s)
            (while (< i n)
                (setq e (ssname s i)
                      x (cdr (assoc -1 (entget e)))
                      ; new import
                      i (1+ i)
                (print x)
I don't have a clue how to combine them. I tried some thing but they didn't work.
Kenny's script  uses
(setq oldlist (entget (car (entsel)))) ; i need to get this information within my loop. -> How to access the entity name from my code ?
(setq thedata '((-3 ("SU-DATA" (1000 . "Kenny is handsome") (1000 . "And intelligent")))))
In a further step i want to copy  a lot of blocks from a different models in a single one. All Items should have the Modelnamefrom their source modell as user data to find them in Navisworks simulate.
Go back and look at part 1 & part 2 carefully study the add XDATA part to an entitity, you have the data but have not say carried out a entmod to add it to the entity.
Hi Bigal,
Thanks for your reply.
I just a posted a part of the script, i didn't want to blow up the post too much.
Kenny's script uses two lists "oldlist" and "thedata" and combines them to the s single list(newdata).
The endmod function is finally assigning thedata to selected entity. This part is fine.
The script itselfs works for a single component which is selected by the user. I just posted the part where the single selection is mentioned.
I want to change the  entget (...) into something that works within the loop.
I tried to  use (entget e) like the script that shows the entitynames.. but got a wrong type error in this line.
(setq oldlist (entget e))
@Chris85 This is correct for the loop in your original post, there must be something else incorrect.
I you look in the snippet from your original pose, (entget e) is already being used.
x (cdr (assoc -1 (entget e)));<---HERE
You have to put your modification code in the loop; I recommend:
            (setq i 0
                  n (sslength s)
            (while (< i n)
                      n (entget e);<---make a variable for the entity list
                      x (cdr (assoc -1 n));<---replace with the new variable
                      xd (assoc -3 n);<---get the xdata
                      i (1+ i);<--increase the counter for the next loop.
                ; =====DO YOUR STUFF HERE====
                (print x)
Try this:
(defun c:addXdata()
  (setq appName "comingFrom"
	data (getvar "dwgname"))
  (regapp appName)
  (setq e1 (car (entsel "select something on THAT layer"))
	ss (ssget "X" (list (assoc 8 (entget e1)))))
    (addXd (ssname ss (setq i (1- i))) appName data))
  (setq ss nil)
(defun c:showXdata()
  (setq en (car (entsel "\nselect object")))
  (setq appName "comingFrom")
  (setq el (entget en (list appName)))
  (princ (strcat "\tThat's a(n) " (cdr (assoc 0 el))))
  (setq xd (cadr (assoc -3 el)))
  (princ (strcat " " (car xd) ": " (cdadr xd)))
(defun addXd(en appName data)
  (setq el (entget en)
	el (append el (list (list -3 (list appName (cons 1000 data))))))
  (entmod el)
