Vladimir74 Posted February 12, 2024 Posted February 12, 2024 Hi, this code should copy only the lines from file dwg2 to file dwg1, and then move the new lines in file dwg1 by 5 along the x-axis. Files dwg1 and dwg2 can be open or closed, and the function can be called from a third file. If the files are placed in MYDOCUMENTS and called "Drawing1.dwg" and "Drawing2.dwg" the function is called with: (DBX_copy (strcat (getvar 'MYDOCUMENTSPREFIX) "\\Drawing1.dwg") (strcat (getvar 'MYDOCUMENTSPREFIX) "\\Drawing2.dwg")) For me, copying lines works fine but moving by 5 on the x-axis using "vla-move" doesn't work. Should "vlax-invoke" be used? Quote (defun DBX_copy (dwg1 dwg2 / doc _odbx doc1 doc2 dbx1 dbx2 toCopyObjects) (setq doc (vlax-get-acad-object)) (defun _odbx (/ v) (if (< (setq v (substr (getvar 'acadver) 1 2)) "16") (vla-getinterfaceobject doc "ObjectDBX.AxDbDocument") (vla-getinterfaceobject doc (strcat "ObjectDBX.AxDbDocument." v)) ) ) (vlax-for openDoc (vla-get-documents doc) (setq currPath (strcase (strcat (vla-get-path openDoc) "\\" (vla-get-name openDoc)))) (if (equal (strcase dwg1) currPath)(setq doc1 openDoc)) ) (if (or (setq dbx1 doc1) (and (setq dbx1 (_odbx)) (not (vl-catch-all-apply 'vla-open (list dbx1 dwg1))))) (progn (vlax-for openDoc (vla-get-documents doc) (setq currPath (strcase (strcat (vla-get-path openDoc) "\\" (vla-get-name openDoc)))) (if (equal (strcase dwg2) currPath)(setq doc2 openDoc)) ) (if (or (setq dbx2 doc2) (and (setq dbx2 (_odbx)) (not (vl-catch-all-apply 'vla-open (list dbx2 dwg2))))) (progn (vlax-for a (vla-get-modelspace dbx2) (if (eq (vla-get-objectname a) "AcDbLine") (setq toCopyObjects (cons a toCopyObjects)) ) ) (if toCopyObjects (setq ss (vlax-invoke dbx2 'copyobjects toCopyObjects (vla-get-modelspace dbx1)))) ; !!!!!!!!!!!!!!!!!!!!!!!!! doesn't work !!!!!!!!!!!!!!!!!!!!!!!!!!!! (setq base_point (vlax-3d-point 0.0 0.0 0.0) insertion_point (vlax-3d-point 5.0 0.0 0.0)) (foreach x ss (vla-move x base_point insertion_point) ) (if (not doc2) (progn (vl-catch-all-apply 'vla-close (list dbx2 :vlax-false)) (vlax-release-object dbx2) (setq doc2 nil dbx2 nil) ) ) ) ) (if (not doc1) (progn (vl-catch-all-apply 'vla-saveas (list dbx1 dwg1)) (vlax-release-object dbx1) (setq doc1 nil dbx1 nil) ) (progn (vl-catch-all-apply 'vla-save (list dbx1)) (vlax-release-object dbx1) (setq doc1 nil dbx1 nil) ) ) ) (print "Something went wrong ;(") ) ) Regards, Vladimir Drawing1.dwg Drawing2.dwg Quote
Vladimir74 Posted February 13, 2024 Author Posted February 13, 2024 Everything works as it should. A shift of 5 was too small to notice. I didn't notice that I drew lines that were much longer than 5 units Morning is wiser than evening. Regards, Vladimir Quote
