LISP or Script to select objects using a specific Property
Hello,
I am currently searching for a way to automate the selection of a set of items based on a property. I have added a custom property via Plant 3D called SpecialtyItem. I want to use this property the select all objects with that property so that I can move those objects to a new Specialty Items layer. I am able to select based on this property using Quick Select but I am hoping to be able to automate this by running a script or LISP to I can build into a button for simple use. I have read over a few things regarding using ssget but it doesn't seem that I can filter based on a certain property of an item, but maybe I am just misinterpreting something. Any help would be appreciated.
You need to find out if the property is at the top level or buried deeper, try this (entget (car (entsel "\npick object"))) paste to command line, have a look at it, see if your Specialtyitem is there.
Else try Dumpit.lsp also to see what properties are revealed at top level.
DumpIt.LSP
Edited by BIGAL
When i paste that into the command line it returns this:
pick object((-1 . <Entity name: 13a2f404320>) (0 . "ACPPPIPEINLINEASSET") (5 . "4DA") (102 . "{ACAD_REACTORS") (330 . <Entity name: 13a2f404350>) (102 . "}") (330 . <Entity name: 13a2e1e91f0>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "P3D-SPECIALTY") (100 . "AcPpDb3dPart") (90 . 66050) (90 . 0) (290 . 0) (290 . 0) (10 0.0 0.0 0.0) (100 . "AcPpDb3dInlineAsset") (340 . <Entity name: 13a2f404120>) (40 . 0.0) (10 2980.86 -1924.13 1410.0) (210 1.0 0.0 0.0) (211 0.0 0.0 1.0) (90 . 0) (100 . "AcPpDb3dPipeInlineAsset"))
Which has no mention of the SpecialtyItem property.
DumpIt.LSP 561 B · 13 downloads
Is there a way to search for properties that arent on the top level?
