Each viewport has an xdata set named "ACAD".
  (setq obj (vlax-ename->vla-object (car(entsel "\nSelect: "))))
  (vla-GetXData obj "ACAD" 'XDataType 'XDataValue)
  (setq dat (vlax-safearray->list XDataType))
  (setq val (vlax-safearray->list XDataValue))
  (mapcar 'print (setq out (mapcar 'vlax-variant-value val)))
the code returns a list xdata of viewport:
"ACAD"
"MVIEW"
16
#<safearray...>
#<safearray...>
0.0
62.4
0.0
0.0
50.0
0.0
0.0
0
1000
1
3
0
0
0
0
0.0
0.0
0.0
0.5
0.5
0.5
0.5
0
How to modify this xdata set?
Can viewports be modified by changing the value of the "ACAD" xdata set?
What are you trying to ? Change size, scale, twist, lock to mention a couple of choices.
Edited by BIGAL
I'm using a 2d viewport.
I want to set the viewport center in model space for coordinate data. I know this can be done by entering the viewport, using zoom, and exiting the viewport.. I'm looking for a method to center the viewport view in model space without going into the viewport. The xdata "ACAD" viewport editing method seems the way to go for this.
Edited by Kowal
This may be a way, note mp is a point in modelspace. This includes a twist angle.
(command "mspace")
(command "zoom" "C" mp 500)
(command "UCS" "Z" ang "plan" "")
(command "UCS" "W")
(command "zoom" "C" mp (strcat (rtos ahsc 2 1) "XP") )
(command "Psltscale" 1)
(command "pspace")
(vla-put-DisplayLocked obj  -1)
