James Willey Posted February 20, 2024 Posted February 20, 2024 If you're as ancient as I am, you may remember the NUMINC lisp routine by Lee Mac Programming. This post hinges off that. Case Problem Setout numbers defined by a block with one attribute. Block inserted using the NUMINC lips routine. After creating the blocks with incremental numeric attribute values from eg. 01 to 99, I've discovered that I've missed one point after eg. 39 or perhaps I need to add a new block due to a design change, how then can I efficiently update the remaining individual blocks to increase their numeric attribute values from 40 to what will now be 100? Is there such a lisp routine that will; Prompt me to select the block in question Use the Attribute Editor in the background perhaps Search for a numeric attribute value (X) Prompt for an integer (Y) to increase or decrease that known value Calculate X+Y=Z Apply the new value (Z) to the attribute Complete the Attribute Editor command Prompt for a new selection or Esc to cancel the routine Thanks in advance. Quote
fuccaro Posted February 20, 2024 Posted February 20, 2024 Here is a Lisp. It can add 1 (or other number) to an integer attribute of many blocks, at once. (defun c:pp() (setq blockName (getstring T "Block name: ") attrName (strcase (getstring T "Attribute: ")) plus (getint "value to add: ")) (setq ss (ssget (list '(0 . "INSERT")(cons 2 blockName)'(66 . 1)))) (repeat (setq i (sslength ss)) (setq en (ssname ss (setq i (1- i)))) (while (and (/= (cdr (assoc 0 (setq el (entget en)))) "SEQEND") (/= (cdr (assoc 2 el)) attrName)) (setq en (entnext en))) (setq el (subst (cons 1 (itoa (+ plus (atoi (cdr (setq ass1 (assoc 1 el))))))) ass1 el) el (entmod el)) ) (setq ss nil) ) Quote
BIGAL Posted February 21, 2024 Posted February 21, 2024 (edited) Just a suggestion, no need to type block name, using nentsel pick the attribute you want to change, this returns the Tag name as a property. pt is the ( cadr ent). Then do (ssget pt '((0 . "Insert")))) from this pull block name. Then can do a ssget using blkname to get all blocks. Now where did I put this code, I use if often. Found it. (setq blk (nentsel "\nPick the block attribute to get tag name ")) (setq pt (cdr blk)) (setq blktagname (cdr (assoc 2 (entget (car blk))))) (setq ent (ssname (ssget pt '((0 . "INSERT"))) 0)) (setq blkname (cdr (assoc 2 (entget ent)))) Edited February 21, 2024 by BIGAL Quote
