ica_cici Posted March 2, 2009 Share Posted March 2, 2009 I read about steel square twisted topic, and I've been practice both ways using lips and sweep but Those methode only for straight form. How can I draw the steel square twisted along path (path made is polyline between round and lines)?. Thankyou for help! Quote Link to comment Share on other sites More sharing options...
Hedgehog Posted March 2, 2009 Share Posted March 2, 2009 I'd use a loft with sections rotated to the correct degree positioned along it's path. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 2, 2009 Share Posted March 2, 2009 Take a peek at some of the similar threads as listed below such as "How to extrude a twisted object" and "Modelling a twisted square steel bar". Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 2, 2009 Share Posted March 2, 2009 I've been practice both ...and sweep but Those methode only for straight form. Do you have access to 2007 or later (Sweep didn't exist in r2004?) Use Twist option. Quote Link to comment Share on other sites More sharing options...
ica_cici Posted March 3, 2009 Author Share Posted March 3, 2009 Actualy I'm using both Autocad 2004 and 2008. I've been trying to use lisp (topic"twisting objects with Autocad R14 - fuccaro") in Autocad 2004 and using sweep in Autocad 2008. It's works but only for bar shape. Now I'm trying to draw this image 'see attachment' (dimension 3.05 x 2.40 square dimension 0.50 mm). What should ido to make a solid drawing for this image. Thanks for help. Quote Link to comment Share on other sites More sharing options...
fuccaro Posted March 3, 2009 Share Posted March 3, 2009 Try the Mobius ring. There is one that twists multiple times. And also there is an elliptical one. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 3, 2009 Share Posted March 3, 2009 Actualy I'm using 2008. Sweep (see attached) Go througth the tutorials in my signature. Chain.zip Quote Link to comment Share on other sites More sharing options...
ica_cici Posted March 4, 2009 Author Share Posted March 4, 2009 Hi JD Mather! Thanks for your tutorial, it's work for me. I use sweep command with this steps : Command: SWEEP Current wire frame density: ISOLINES=4 Select objects to sweep: 1 found Select objects to sweep: Select sweep path or [Alignment/Base point/Scale/Twist]: b Specify base point: Select sweep path or [Alignment/Base point/Scale/Twist]: t Enter twist angle or allow banking for a non-planar sweep path [bank]: 720 Select sweep path or [Alignment/Base point/Scale/Twist]: And the result is amazing. Thank you so much. square twist.dwg Quote Link to comment Share on other sites More sharing options...
