Another question folks,
when I draw a pline, and chang to arcmode, I cannot see the preview for the arc until I click the endpoint. Thus, I can't see where the arc is before I finish it. I believe there is a switch for this, or could it be my graphics card is crap?
Ha ha... same issue... PLINETYPE is 0... set it to 1 or 2 :wink:
..that didn't work for me, are you sure this changed the problem for you?
Yup... on 2007... it's set to 2 as the default but switch it to 0 & neither the arcs show in preview nor the snaps work. Maybe there's another system variable that can effect this.
... correction... the arc previews still work in a plan ucs but not a tilted one with PLINETYPE=0... with PLINETYPE=2 they preview regardless of ucs.
sounds good, but I still can't fix it on the 2007 I'm on..
