solved: ssget error when using Fence method
EnM4st3r
Hi everyone,
I ran into a issue and i dont know why.. maybe someone knows.
Edit: found the issue.. thats because i need to proivde points to ssget when using that method.
         Odd  that its not written on the ssget documentation.. maybe im just blind tough
Edited by EnM4st3r
  • EnM4st3r changed the title to solved: ssget error when using Fence method
12 hours ago, Lee Mac said:
You might find my ssget Function Reference of interest - it contains slightly more information than the standard documentation.
Thanks 👍
6 hours ago, BIGAL said:
Do you mean (ssget "F" pts) ? Where pts is a list of points say a pline vertices.
Yes
On 3/2/2024 at 2:57 AM, BIGAL said:
So explain more about what it is your trying to do, need a dwg etc to look at.
its alright, as i said i found the issue already. Its just that i couldnt understand why i did not work at first.
