sanshef Posted March 3, 2009 Posted March 3, 2009 Hi, i am new to this forum. I am using autocad 2008 version. Would like to know how I can import layers from other drawings to current drawing? Regards, Sanshef Quote
lpseifert Posted March 3, 2009 Posted March 3, 2009 Use Design Center (Ctrl+2). Navigate to the source dwg, expand Layers, Drag and Drop. Quote
sanshef Posted March 3, 2009 Author Posted March 3, 2009 Thanks a bunch lpseifert... Will try it... Sanshf Quote
darn-net Posted March 3, 2009 Posted March 3, 2009 You could also use matchprop to match properties between open drawings. It works well to copy dimension styles also. After you select an object the command line gives you an option for settings. The settings lets you control what you want to match. Quote
RichterGMC Posted March 3, 2009 Posted March 3, 2009 All I do is copy a line or something in that is on that layer into the drawing that I want the layer to be in, and then delete the object. The layer will remain there. Quote
Cad64 Posted March 3, 2009 Posted March 3, 2009 All I do is copy a line or something in that is on that layer into the drawing that I want the layer to be in, and then delete the object. The layer will remain there. What if you need to bring in 100 layers? Design Center is the way to go. You can bring in the layers without all of the dimstyles, textstyles, linetypes etc. that come in with geometry. Quote
RichterGMC Posted March 3, 2009 Posted March 3, 2009 What if you need to bring in 100 layers? Design Center is the way to go. You can bring in the layers without all of the dimstyles, textstyles, linetypes etc. that come in with geometry. Then I guess you would use design center :wink: Quote
