ElAmigo Posted March 11 Share Posted March 11 Hello friends, I have the follow piece of code: (while (< i (sslength selectie)) (setq ent (ssname selectie i)) ; Takes every entity out of the selection (setq data (entget ent)) (if (= (cdr (assoc 0 data)) "DIMENSION") ; Checks if it is a dimension (progn (setq newData (subst (cons 3 DimStyleOverride2) (assoc 3 data) data)) ; Changes DIMSTYLE to variable DimStyleOverride2 (entmod newData) (entupd ent) ) ) (setq i (+ i 1)) ) "selectie" is a selection made beforehand in the code. This code changes the dimstyle to a variable set beforehand. This code is part of an upscaling tool. The problem is, it does update the dimstyle but doesn't show it. Text height is not correct and the measurements don't update correctly. When I manually change the dimstyle and change it back to this variable it does show every change that has to be made. Regen doesn't work either. I hope someone knows an answer to this problem Quote Link to comment Share on other sites More sharing options...
fuccaro Posted March 11 Share Posted March 11 Run your Lisp and do a REGEN by hand. If it works, include REGEN in the program. Quote Link to comment Share on other sites More sharing options...
ElAmigo Posted March 11 Author Share Posted March 11 (edited) 51 minutes ago, fuccaro said: Run your Lisp and do a REGEN by hand. If it works, include REGEN in the program. REGEN didn't work. But I luckily did find a different solution using the following commands: (command "_.-DIMSTYLE" "_R" DimStyleOverride2 "") ;; Sets current dimstyle (command "_-DIMSTYLE" "_A" ent "") ;; Apllies current dimstyles to selected entities Edited March 11 by ElAmigo Quote Link to comment Share on other sites More sharing options...
