inverso Posted March 13 Share Posted March 13 Hello, I don't even know if automizing this kind of sequence is possible but I figured it's worth a shot. Right now I got around 600 xrefs to attach to a single file and their names corelate to the position I want them in a drawing. For example I got filenames like "100, 101, 102, 103, 110, 111, 300, 301, 500, 501, 600" and I want them import all of them at once and set them so that whenever first number changes, it begins a new column of attached drawings: drawings 100, 101, 102, 103, 110, 111 would one under another in first column, drawings 300, 301 would be in second column etc. Is it even possible to create a lisp that would do that? Thank you in advance! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 14 Share Posted March 14 Its doable as you check name as say a number not a string, so can work out via a Cond which column to use. Just thinking do COND backwards. (cond ((> dgwnum 1100)(setq num 11)) ((> dgwnum 1000)(setq num 10)) ((> dgwnum 900)(setq num 9)) .......... ((> dgwnum 100)(setq num 1)) ((< dgwnum 100)(setq num 0)) ) Quote Link to comment Share on other sites More sharing options...
