AUTOCAD IS MY LIFE Posted March 14 Share Posted March 14 IS THERE ANY WAY TO COPY AND INCREASE THE LAST CHARACTER AND OVERWRITE THE EXISTING TEXT? Quote Link to comment Share on other sites More sharing options...
EnM4st3r Posted March 14 Share Posted March 14 yes there is 2 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted March 14 Share Posted March 14 To add to the above answer. I can't remember asking but what are your LISP abilities like? - Select text using entsel or ssget with (ssname ss n) to get the entity name, entget that to get the definition - Check you are processing a text entity - Use assoc and the entget, value 1 to get the text string - Then you can work out the increment portion - repeat the fuirst steps again to select the next text and use entmod to update the text 1 Quote Link to comment Share on other sites More sharing options...
AUTOCAD IS MY LIFE Posted March 15 Author Share Posted March 15 (defun ketthuc () (setvar "cmdecho" luuecho) (setq *error* luu luu nil luuecho nil );setq (princ) ) ;********************************************************************* (defun modau () (setq luu *error luuecho (getvar "cmdecho") *error (ketthuc) ) ) ;********************************************************************* (defun xulytext (text / kytu ma sokt luusokt lui ) (setq kytu (substr text (strlen text)) ma (ascii kytu) sokt (read kytu) lui 1 ) (if (numberp sokt) (progn (setq luusokt (1+ sokt)) (if (and (numberp sokt) (> (strlen text) 1) ) (progn (setq kytu (substr text (1- (strlen text))) sokt (read kytu) ) (if (numberp sokt) (setq luusokt (1+ sokt) lui 2 ) ) );progn ) (if (= luusokt 100) (setq luusokt 0)) (setq kytu (rtos luusokt 2 0) text (strcat (substr text 1 (- (strlen text) lui)) kytu) ) );progn (if (or (= kytu "z") (= kytu "Z") ) (setq text (strcat text "0") textxl "0" ) (setq ma (1+ ma) text (strcat (substr text 1 (1- (strlen text))) (chr ma)) ) );if );if ) ;********************************************************************* (defun doitext(tendoituong / chuoi doituong thoat tam dsach kieu text vitri10 vitri11 dem canle) ;Neu doi tuong la text thi tiep tuc (setq doituong (entget tendoituong) kieu (cdr (assoc 0 doituong)) canle (cdr (assoc 72 doituong)) ) (if (or (= kieu "TEXT") (= kieu "MTEXT") ) (progn (setq textxl (xulytext textxl) text (cons 1 textxl) vitri10 (cdr (assoc 10 doituong)) vitri10 (list (+ (car vitri10) (car vitrilech)) (+ (nth 1 vitri10) (nth 1 vitrilech))) vitri10 (cons 10 vitri10) vitri11 (cdr (assoc 11 doituong)) vitri11 (list (+ (car vitri11) (car vitrilech)) (+ (nth 1 vitri11) (nth 1 vitrilech))) vitri11 (cons 11 vitri11) dem 0 dsach nil ) (foreach tam doituong (cond ((= (car tam) 1) (setq dsach (append dsach (list text)))) ((= (car tam) 10) (setq dsach (append dsach (list vitri10)))) ((= (car tam) 11) (setq dsach (append dsach (list vitri11)))) ((setq dsach (append dsach (list tam)))) ) ) (entmake dsach) );progn );if ); ;********************************************************************* ;sao doi tuong cu sang vi tri moi (defun copy_dt (tendoituong ) (command "copy" tendoituong "" goc toi ) );defun ;********************************************************************* (defun c:CT ( / cumdt dodai thoat dem ten doituong textxl dem goc toi) ; Khoi dau cua chuong trinh (princ "\nCopy thong minh...\n") (setq luuecho (getvar "cmdecho") luu *error* *error* ketthuc cumdt (ssget) dodai (sslength cumdt) goc (getpoint "\nDiem goc copy:") thoat nil dem 0 textxl nil ); (setvar "cmdecho" 0) ; Loc ra duoc ong text de xu ly (while (and (= thoat nil) (< dem dodai) ) (setq ten (ssname cumdt dem) dem (1+ dem) doituong (entget ten) kieu (cdr (assoc 0 doituong)) ) (if (or (= kieu "TEXT") (= kieu "MTEXT") ) (setq thoat T textxl (cdr (assoc 1 doituong)) ) ) ); (while T (setq toi (getpoint "\nDiem dat doi tuong: " goc) vitrilech (list (- (car toi) (car goc)) (- (nth 1 toi) (nth 1 goc))) dem 0 ) (while (< dem dodai) (setq ten (ssname cumdt dem) dem (1+ dem) doituong (entget ten) kieu (cdr (assoc 0 doituong)) ) (if (or (= kieu "TEXT") (= kieu "MTEXT") ) (doitext ten) (copy_dt ten) );if ) );while (ketthuc) );defun (princ) my lisp is only copy and increase 2 last character but create a new text , can you help me develop this lisp can overwrite the existing text 1 Quote Link to comment Share on other sites More sharing options...
