HockeyGeek Posted March 4, 2009 Share Posted March 4, 2009 Is there a way to have my VP scale at 1"=100' and my Annotation scale at 1"=20'. I do not want my linetypes to scale to 1"=100'. They have text in it and they become to large for the look of the drawing. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted March 4, 2009 Share Posted March 4, 2009 Make sure your VP is unlocked, click on it. In properties you can set the scales. You can set the Linetype scale factor for individual lines in Properties also. Quote Link to comment Share on other sites More sharing options...
chulse Posted March 4, 2009 Share Posted March 4, 2009 Just curious, but what is your global LTSCALE set to? Quote Link to comment Share on other sites More sharing options...
HockeyGeek Posted March 4, 2009 Author Share Posted March 4, 2009 ltscale is set to 1. msltscale set to 1. psltscale set to 1. Quote Link to comment Share on other sites More sharing options...
daham Posted March 13, 2009 Share Posted March 13, 2009 but they still seem to be locked together, the VP scale and the annotation scale--whether in properties palette or under the viewport, if i change one scale, it changes the other to correspond Quote Link to comment Share on other sites More sharing options...
lpseifert Posted March 13, 2009 Share Posted March 13, 2009 Works for me, try setting them in different order Quote Link to comment Share on other sites More sharing options...
daham Posted March 13, 2009 Share Posted March 13, 2009 thanks, that does the trick--the only glitch is that when you set the annotation scale, the viewport scale automatically switches to correspond, but then you can change the viewport scale afterwards without the annotation scale also changing. Quote Link to comment Share on other sites More sharing options...
