DEAR ALL
PLZ HELP ME
CAN U MAKE THIS TYPE OF LSP
ROOM SIZE.LSP
1) ROOM TITLE LAYER & TEXT STYLE
2) ROOM SIZE IN METER & TEXT STYLE
3) ROOM SIZE IN FEET & TEXT STYLE
CARPET AREA.LSP
1) CARPET AREA LAYER & TEXT STYLE
2) CARPET AREA IN SQ. METER & TEXT STYLE
3) CARPET AREA IN SQ. FEET & TEXT STYLE
SORRY FOR BAD ENGLISH
THNX
ROOM SIZE.pdf
CARPET AREA.pdf
look at cadtips.cadalyst.co you could dig something up
i cant place web stuff
am mastering basic
Time to hang out the sign:
Custom Lisp Routines Designed While You Wait.
No appointment necessary.
Haha, so true.
So many users think this place is just a LISP supermarket, and don't realise its only really for help and advice.
It's the mentality of "I'll pay you anything you want as long as you except Monopoly money."
In no way is this meant to belittle the talent that you, Lee Mac and others, have for developing Lisp routines. On the contrary, I'm amazed at the speed in which you pull this off, making the task appear to be almost effortless.
I'd like to see requests like this be worded a bit more politely. And I'd also like to see the OP show his/her appreciation with a well intentioned and gracious word of thanks. It's the least anyone can do when a custom lisp routine is wonderously conjured out of thin air at a moment's notice.
So, on behalf of all the people you and others have helped, I sincerely thank you for the thought you've put into writing these lisp routines, for the effort you have made to help them with their problem, for the educational value of your follow-up posts regarding the formation of a good lisp routine and for the dedication you have shown in doing so without renumeration.
Thank you...Thank you...Thank you.
ReMark, you are too kind :P
I suppose this is a start:
(defun c:roomsize (/ ent vLst xlst ylst xrange yrange)
 (if (and (setq ent (car (entsel "\nSelect Wall...")))
      (eq "LWPOLYLINE" (cdadr (entget ent))))
     (setq vLst (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) (entget ent)))
       xlst (mapcar '(lambda (y) (car y)) vLst)
       ylst (mapcar '(lambda (z) (cadr z)) vLst)
       xrange (- (apply 'max xlst) (apply 'min xlst))
       yrange (- (apply 'max ylst) (apply 'min ylst)))
     (alert (strcat (rtos xrange) "x" (rtos yrange)
            "\n" (rtos xrange 3) "x" (rtos yrange 3))))
   (princ "\n<!> No Wall Selected or This isn't an LWPOLYLINE <!>"))
 (princ))
I had nothing better to do :)
Taking it a little further... (slap-dash LISPing, just throwing it together..)
(defun c:roomsize (/ ent vLst xlst ylst xrange yrange area)
     (setvar "CMDECHO" 0)
     (command "_area" "_Object" ent) (setq area (getvar "AREA"))
     (alert (strcat (rtos xrange) " x " (rtos yrange)
            "\n" (rtos xrange 3) " x " (rtos yrange 3)
            "\n" (rtos area) " SQ.MT.\n" (rtos area 3) " SQ.FT.")))
 (setvar "CMDECHO" 1)
 (princ))
WILL PROGRAM FOR BEER!
At least they should pretend to want to learn how to program
(defun c:freeProgram ()
;;;I’m stuck here can someone please fill in the rest
);_defun
);_defun
Haha John - you sum it up quite nicely. :)
I reckon we should have a "rant" forum, where everyone just posts threads about what really gets on their nerves... :P
);_defun
There's going to be BEER!! I'm there
Here is some room names things to play with.
RoomNames.zip
