itacad Posted March 19 Share Posted March 19 Hello, in a drawing I use a block with attributes. The same attributes in some cases must be shown and in other cases not. The only system I have devised is to give membership to a specific frozen layer in cases where the attribute should not be shown. I ask for clarification: it is not possible to set the visibility of an attribute of a block at discretion, correct? In practice, I cannot in a file use the same block in some cases with visible attributes and in some cases with non-visible attributes, correct? Greetings Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 20 Share Posted March 20 (edited) You can entmod a attribute. (setq ent (entget (car (nentsel "\nPick an attribute to turn off")))) (entmod (subst (cons 70 1) (assoc 70 ent) ent)) Turning back on is a bit harder unless you know tag name, or just turn all attributes on then do off again. (70 . 0) is on. Edited March 20 by BIGAL Quote Link to comment Share on other sites More sharing options...
