Aftertouch Posted March 21 Share Posted March 21 (edited) UPDATE: Solved it.... was quite a simple fix: (defun BGBLXCLIPEXP( entdata / ent) (bg:block-xclip-exp (car entdata) (cadr entdata)) (princ) ) Where the entdata is de list that you get with (entget) Hi all, I want to explode a block with a clipping, and only keep the visual part of the block as a result. The code below does exactly what i want, BUT..... The top command 'BGBLXCLIPEXP' asks me to select a block with a clipping, and then does what it needs to do. I want to put this in a 'loop', so my selectionset can be fed into this function. However.... The command is made with quite some complex funtions, and i dont understand 'how' it works. I prefer Vanilla Lisp bij far! I want to change the defun to: (defun BGBLXCLIPEXP( entid / ent) And i need to remove this line so i dont have to make a selection anymore. (vl-catch-all-apply 'entsel (list (if (= (getvar "DWGCODEPAGE") "ANSI_1251") "\nÓêàæèòå ïîäðåçàííûé áëîê: " "\nSelect clipped block")) ) But where do i need to put my imput 'entid' now? (defun c:BGBLXCLIPEXP( / ent) (vl-load-com) ((lambda(ent actdoc) (vla-startundomark actdoc) (if (and ent (not (vl-catch-all-error-p ent)) ) ((lambda(obj point) (if (bg:block-GetXclip (vlax-ename->vla-object obj)) (bg:block-xclip-exp obj point) (prompt (if (= (getvar "DWGCODEPAGE") "ANSI_1251") "\nÓêàçàííûé áëîê íå ïîäðåçàí" "\nThe specified block is not clipped")) ) ) (car ent) (cadr ent) ) ) (vla-endundomark actdoc) ) (vl-catch-all-apply 'entsel (list (if (= (getvar "DWGCODEPAGE") "ANSI_1251") "\nÓêàæèòå ïîäðåçàííûé áëîê: " "\nSelect clipped block")) ) (vla-get-activedocument (vlax-get-acad-object)) ) (princ) ); end c:BGBLXCLIPEXP (defun bg:block-GetXclip ( vla-obj / result ) (vl-catch-all-apply '(lambda ( ) (if (and (eq (vla-get-ObjectName vla-obj) "AcDbBlockReference") (eq :vlax-true (vla-get-HasExtensionDictionary vla-obj) ) ) (setq result (entget (vlax-vla-object->ename (vla-item (vla-item (vla-getExtensiondictionary vla-obj) "ACAD_FILTER" ) "SPATIAL" ) ) ) ) ) ) ) result ) (defun bg:block-xclip-exp(blk point / pline_obj *error*) (defun *error* (msg) (princ msg) (mapcar '(lambda (x)(if(vlax-write-enabled-p x)(vla-put-visible x :vlax-true))) hiden) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) ) (if (vl-cmdf "_.xclip" blk "" "_P") ((lambda(pline_obj) (vl-cmdf "_.zoom" "_O" pline_obj "") ((lambda(lst_exp_obj lst_xclip eps) (if (and lst_exp_obj lst_xclip ) ((lambda(is_int_point) ((lambda(nbr_xclip pline_trim / i e1) (setq i 0 ss (ssadd)) (while (< i (sslength nbr_xclip)) (if (not(vl-position(vlax-ename->vla-object(setq e1(ssname nbr_xclip i))) lst_exp_obj)) (progn (setq hiden (cons (vlax-ename->vla-object e1) hiden)) (ssdel e1 nbr_xclip) ) (setq i (1+ i)) ) ) (mapcar '(lambda (x)(if(vlax-write-enabled-p x)(vla-put-visible x :vlax-false))) hiden) (VL-CATCH-ALL-APPLY '(lambda() (if (and nbr_xclip pline_trim) (progn (foreach item (mapcar 'vlax-vla-object->ename lst_exp_obj) (if is_int_point (if (not (ssmemb item nbr_xclip)) (entdel item) ) (if (ssmemb item nbr_xclip) (entdel item) ) ) ) (apply 'vl-cmdf (append (list "_.trim" pline_obj "" "_F") ((lambda(ed_pline_trim) (append (mapcar 'cdr (vl-remove-if-not (function (lambda(x) (= (car x) 10))) ed_pline_trim ) ) (list (cdr (assoc 10 ed_pline_trim))) ) ) (entget pline_trim) ) (list "" "") ) ) (entdel pline_trim) ) ) )) (mapcar '(lambda (x)(if(vlax-write-enabled-p x)(vla-put-visible x :vlax-true))) hiden) (vl-cmdf "_.zoom" "_P") ) (if is_int_point (ssget "_CP" lst_xclip) (ssget "_WP" lst_xclip) ) ((lambda(reverse-point) (if reverse-point (if (vl-cmdf "_.offset" eps pline_obj (get-reverse-point point pline_obj 0.1) "") (entlast) ) ) ) (get-reverse-point point pline_obj 0.1) ) ) ) ((lambda(point_obj / result) (setq result (ssmemb point_obj (ssget "_CP" lst_xclip))) (entdel point_obj) result ) (entmakex (list '(0 . "POINT") (cons 10 point))) ) ) ) ) (bg:burst-list blk) (mapcar 'cdr (vl-remove-if-not (function (lambda(x) (= (car x) 10))) (entget pline_obj))) (min 0.1 (* (getvar 'viewsize) 0.01)) ) (entdel pline_obj) (vl-cmdf "_.zoom" "_P") ) (entlast) ) ) ) (defun bg:burst-list (blk / ret ELAST ENAME ENT) (if (= (type blk) 'VLA-OBJECT)(setq blk (vlax-vla-object->ename blk))) (Setq ELAST (LASTENT)) (bg:BURST-ONE blk) (setq ENAME ELAST ret nil) (While (Setq ENAME (EntNext ENAME)) (setq ENT (entget ENAME)) (if (and (assoc 60 ENT);_(check Visible dxf code 60) if code 60 set to 1 - object invisible (= 1 (cdr(assoc 60 ENT))) ) (VL-CATCH-ALL-APPLY 'entdel (list ENAME)) (setq ret (cons (vlax-ename->vla-object ENAME) ret)) ) ) ret) (Defun LASTENT (/ E0 EN) ;----------------------------------------------------- ; Find True last entity ;----------------------------------------------------- (Setq E0 (EntLast)) (While (Setq EN (EntNext E0)) (Setq E0 EN) ) E0 ) (Defun bg:BURST-ONE (BNAME / BBLOCK BENT ANAME ENT ATYPE AENT AGAIN ENAME ENT SS-COLOR SS-LAYER SS-LTYPE SS-LWEIGHT mirror ss-mirror TMP mlast BLAYER BCOLOR BLTYPE BLWEIGHT attlist BOBJ _ITEM _bump _ATT-TEXT SS-ATTR ) ;;;********* Ô-öèè âûäðàíû èç BURST.LSP ************ ;;; Íàëè÷èå Express îáÿçàòåëüíà !!! (Defun _ITEM (N E) (CDR (Assoc N E))) ;;;(acet-error-init (list (list "cmdecho" 0 ;;;"highlight" 1) T)) ;;;(Defun _BITSET (A B) (= (Boole 1 A B) B)) (Defun _bump (prmpt)(GRTEXT -2 prmpt)) (Defun _ATT-TEXT (AENT / ANAME TENT ILIST INUM lineweight) (setq ANAME (cdr (assoc -1 AENT))) (if (and _MATTS_UTIL (_MATTS_UTIL ANAME)) (progn ; Multiple Line Text Attributes (MATTS) - ; make an MTEXT entity from the MATTS data (_MATTS_UTIL ANAME 1) ) (progn ; else -Single line attribute conversion (Setq TENT '((0 . "TEXT"))) (ForEach INUM '(8 6 38 39 62 67 210 10 40 1 50 41 51 7 71 72 73 11 74) (If (Setq ILIST (Assoc INUM AENT)) (Setq TENT (Cons ILIST TENT)) ) ) (Setq tent (Subst (Cons 73 (_ITEM 74 aent)) (Assoc 74 tent) tent ) ) ;;; VVA ADD 2011-10-26 BEGIN ((lambda ( itm / ed next) (setq next t) (while (and next (setq itm (entnext itm))) (setq ed (entget itm)) (if (and (= (_ITEM 0 ed) "ATTDEF") (= (_ITEM 2 ed)(_ITEM 2 AENT)) ) (setq next nil lineweight (_ITEM 370 ed)) ) ) ) (tblobjname "BLOCK" (bg:block-get-name (cdr(assoc 330 AENT)))) ) (cond ((= lineweight '-3) ;_default lineweight (setq TENT (cons (cons 370 (getvar "LWDEFAULT")) TENT)) ) ((= lineweight '-2) ;_byblock lineweight (if (setq lineweight (cdr(assoc 370 (entget(cdr(assoc 330 AENT)))))) (setq TENT (cons (cons 370 lineweight) TENT)) ((lambda ( lw ) (cond ((= lw '-3) (setq TENT (cons (cons 370 (getvar "LWDEFAULT")) TENT)) ) ((numberp lw) (setq TENT (cons (cons 370 lw) TENT)) ) (t nil) ) ) (cdr(assoc 370 (entget(TBLOBJNAME "LAYER" (cdr(assoc 8 (entget(cdr(assoc 330 AENT))))))))) ) ) ) ((and lineweight (not (minusp lineweight))) (setq TENT (cons (cons 370 lineweight) TENT)) ) (t ;_bylayer ((lambda ( lw ) (cond ((= lw '-3) (setq TENT (cons (cons 370 (getvar "LWDEFAULT")) TENT)) ) ((numberp lw) (setq TENT (cons (cons 370 lw) TENT)) ) (t nil) ) ) (cdr(assoc 370 (entget(TBLOBJNAME "LAYER" (cdr(assoc 8 (entget(cdr(assoc 330 AENT))))))))) ) ) ) ;;; VVA ADD 2011-10-26 END (EntMakex (Reverse TENT)) ) ) ) ;_ end of Defun (Setq BENT (EntGet BNAME) BOBJ (vlax-ename->vla-object BNAME) BLAYER (vla-get-Layer BOBJ) BCOLOR (vla-get-Color BOBJ) BBLOCK (bg:block-get-name BNAME) ;;; (_ITEM 2 BENT) BLTYPE (vla-get-linetype BOBJ) BLWEIGHT (vla-get-LineWeight BOBJ) SS-ATTR (ssadd) ) (Setq ELAST (LASTENT) attlist nil) (if (bg:EXPLODABLE BBLOCK) (progn (If (= 1 (_ITEM 66 BENT)) (Progn (Setq ANAME BNAME) (While (Setq ANAME (EntNext ANAME) AENT (EntGet ANAME) ATYPE (_ITEM 0 AENT) AGAIN (= "ATTRIB" ATYPE) ) ;;; (_bump "Converting attributes") ;;;-> VVA 30.07.2008 (if (or (null(_ITEM 60 AENT)) (/= (_ITEM 60 AENT) 1) ;_ Visible ON (check dxf code 60) if code 60 set to 1 - object invivible ) (if (or (zerop (logand (_ITEM 70 AENT) 1)) ;_Change by VVA Attr fix 03.09.2008 Not hidden attribute (zerop (logand (_ITEM 70 AENT) 9)) ;_Add kakt00z 1.06.2010 ( http://forum.dwg.ru/showpost.php?p=580531&postcount=33 ) ) (progn (setq tmp (cdr (assoc 2 AENT))) ;_ add VVA 20.03.2009 (_ATT-TEXT AENT) ;_Change by VVA Attr fix 03.09.2008 (setq attlist (cons (list tmp (entlast)) attlist)) ;_ add VVA 20.03.2009 ) ) ) ) ) ) ;;;<- VVA 30.07.2008 (_bump (strcat "Exploding block " BBLOCK)) ;;; Ñíà÷àëà ïûòàåìñÿ âçîðâàòü ìåòîäîì vla-explode (if (VL-CATCH-ALL-ERROR-P (VL-CATCH-ALL-APPLY 'vla-Explode (list(vlax-ename->vla-object BNAME))) ) (acet-explode BNAME) (VL-CATCH-ALL-APPLY 'vla-delete (list(vlax-ename->vla-object BNAME))) ) (Setq SS-LAYER nil SS-COLOR nil SS-LTYPE nil SS-LWEIGHT nil ;_Add VVA BURST LWEIGHT SECTION ENAME ELAST ) ;;; (_bump "Gathering pieces") (While (Setq ENAME (EntNext ENAME)) (Setq ENT (EntGet ENAME) ETYPE (_ITEM 0 ENT) ) (cond ((= "ATTDEF" ETYPE) (setq tmp (cdr(assoc 2 ENT))) ;_ add VVA 20.03.2009 (if (cadr (assoc tmp attlist)) (ssadd (cadr (assoc tmp attlist)) SS-ATTR) ) (setq attlist (bg:del-from-list tmp attlist)) ;_ add VVA 13.07.2010 ;;; (If (_BITSET (_ITEM 70 ENT) 2) ;_Rem by VVA Attr fix 03.09.2008 ;;; (ATT-TEXT ENT) ;_Rem by VVA Attr fix 03.09.2008 ;;; ) ;_Rem by VVA Attr fix 03.09.2008 (EntDel ENAME) ) ((= "SEQEND" ETYPE) nil) ((and (_ITEM 60 ENT);_(check Visible dxf code 60) if code 60 set to 1 - object invisible (= 1 (_ITEM 60 ENT)) ) (VL-CATCH-ALL-APPLY 'entdel (list ENAME)) ) (t ;_Other entyties (If (= "0" (_ITEM 8 ENT)) (setq SS-LAYER (cons ENAME SS-LAYER)) ) (If (= 0 (_ITEM 62 ENT)) ;_ -> START Change VVA BURST (if (= "0" (_ITEM 8 ENT)) (setq SS-COLOR (cons ENAME SS-COLOR)) (progn (if (null (_ITEM 62 BENT)) ;_Block color type bylayer ;;;(command "_.chprop" ENAME "" "_C" (_ITEM 62 (entget (TBLOBJNAME "LAYER" BLAYER))) "") (bg:change-prop ENAME "Color" (_ITEM 62 (entget (TBLOBJNAME "LAYER" BLAYER)))) (setq SS-COLOR (cons ENAME SS-COLOR)) ) ) ) ;_ <- END Change VVA BURST ) (If (= "BYBLOCK" (strcase (cond ((_ITEM 6 ENT))("")))) ;_ -> START Change VVA BURST (if (= "0" (_ITEM 8 ENT)) (setq SS-LTYPE (cons ENAME SS-LTYPE)) (progn (if (= "BYLAYER" (strcase (cond ((_ITEM 6 BENT))("BYLAYER")))) ;_Block line type bylayer ;;;(command "_.chprop" ENAME "" "_LT" (_ITEM 6 (entget (TBLOBJNAME "LAYER" BLAYER))) "") (bg:change-prop ENAME "Linetype" (_ITEM 6 (entget (TBLOBJNAME "LAYER" BLAYER)))) (setq SS-LTYPE (cons ENAME SS-LTYPE) ) ) ) ) ) ;_ <- END Change VVA BURST ;_ -> START Change VVA BURST LWEIGHT SECTION (If (= -2 (_ITEM 370 ENT)) ;_ -> BYBLOCK LWEIGHT (if (= "0" (_ITEM 8 ENT)) (setq SS-LWEIGHT (cons ENAME SS-LWEIGHT)) (progn (if (NOT (_ITEM 370 BENT)) ;_Block LWEIGHT BYLAYER (bg:change-prop ENAME "LineWeight" (vla-get-LineWeight (vlax-ename->vla-object (TBLOBJNAME "LAYER" BLAYER)))) (setq SS-LWEIGHT (cons ENAME SS-LWEIGHT)) ) ) ) ) ;_ <- END Change VVA BURST LWEIGHT SECTION ) ) ) (foreach itm attlist ;_ add VVA 20.03.2009 (if itm (progn ;_ add VVA 20.03.2009 (setq tmp (cadr itm)) ;_ add VVA 20.03.2009 (setq SS-LAYER (VL-REMOVE tmp SS-LAYER)) ;_ add VVA 20.03.2009 (setq SS-COLOR (VL-REMOVE tmp SS-COLOR)) ;_ add VVA 20.03.2009 (setq SS-LTYPE (VL-REMOVE tmp SS-LTYPE)) ;_ add VVA 20.03.2009 (setq SS-LWEIGHT (VL-REMOVE tmp SS-LWEIGHT)) ;_ add VVA 20.03.2009 (if (= (type tmp) 'ENAME) (ENTDEL tmp) ;_ add VVA 20.03.2009 ) ) ;_ add VVA 20.03.2009 ) ;_ add VVA 20.03.2009 ) ;_ add VVA 20.03.2009 (foreach itm SS-LTYPE (bg:change-prop itm "Linetype" BLTYPE) ) (foreach itm SS-COLOR (bg:change-prop itm "Color" BCOLOR) ) (foreach itm SS-LWEIGHT (bg:change-prop itm "LineWeight" BLWEIGHT) ) (foreach itm SS-LAYER (bg:change-prop itm "Layer" BLAYER) ) ) (_bump (strcat "Block " BBLOCK " not Explodable. Ignored. ")) ) (if (> (sslength SS-ATTR) 0)(command "_draworder" SS-ATTR "" "_f")) (setq SS-LAYER nil SS-COLOR nil SS-LTYPE nil SS-LWEIGHT NIL SS-ATTR NIL) ) (defun bg:block-get-name (blockentity / name repbtag ) (if (eq (type blockentity) 'VLA-OBJECT)(setq blockentity (vlax-vla-object->ename blockentity))) ;;;get from Lee Mac LM:EffectiveName ;;; http://www.theswamp.org/index.php?topic=37493.0 ;;; http://forum.dwg.ru/showthread.php?t=65082 ;;----------------=={ Effective Block Name }==----------------;; ;; ;; ;; Returns the effective name of a block. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; blockentity - Block Reference Entity name ;; ;;------------------------------------------------------------;; ;; Returns: True block name as per the block definition ;; ;;------------------------------------------------------------;; (if (wcmatch (setq name (cdr (assoc 2 (entget blockentity)))) "`**") (if (and (setq repbtag (cdadr (assoc -3 (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" name)) ) ) '("AcDbBlockRepBTag") ) ) ) ) (setq repbtag (handent (cdr (assoc 1005 repbtag)))) ) (setq name (cdr (assoc 2 (entget repbtag)))) ) ) name ) (Defun bg:EXPLODABLE (BNAME / B expld) (setq BLOCKS (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object))) ) (vlax-for B BLOCKS (if (and (= :vlax-false (vla-get-islayout B)) (= (strcase (vla-get-name B)) (strcase BNAME)) ) (if (vlax-property-available-p B "explodable") ;;; VVA Correct to 2004 AutoCAD (setq expld (= :vlax-true (vla-get-explodable B))) (setq expld t) ) ) ) expld ) (defun bg:change-prop ( obj prop value) (if (= (type obj) 'ENAME) (setq obj (vlax-ename->vla-object obj)) ) (if (and (vlax-write-enabled-p obj) (vlax-property-available-p obj prop) ) (vl-catch-all-apply 'vlax-put-property (list obj prop value)) ) ) (defun get-reverse-point(pt obj e / ) ((lambda(cl_pt) (if cl_pt ((lambda(param_cl_pt end_param) (if param_cl_pt ((lambda(p1 p2) (if (not p1) (setq p1 (vlax-curve-getPointAtParam obj e))) (if (not p2) (setq p2 (vlax-curve-getPointAtParam obj (- end_param e)))) ((lambda(c_p) (polar pt (angle pt c_p) (+ (distance pt c_p) e)) ) (polar p1 (angle p1 p2) (* (distance p1 p2) 0.5)) ) ) (vlax-curve-getPointAtParam obj (+ param_cl_pt e)) (vlax-curve-getPointAtParam obj (- param_cl_pt e)) ) ) ) (vlax-curve-getParamAtPoint obj cl_pt) (vlax-curve-getEndParam obj) ) ) ) (vlax-curve-getClosestPointTo obj pt) ) ); end get-reverse-point Edited March 21 by Aftertouch Quote Link to comment Share on other sites More sharing options...
