Routine check please...
Sharper
Hi Guys
I've made this lisp routine for getting the area of a shape using ssget...
Sometimes it works fine and sometimes it fails with the following error
Autolisp Error: ActiveX Server returned the error: unknown name: Area
Could someone please take a look and let me know where i've gone wrong?
many thanks
;Checks  area. min size of 30000mm2 set.
(defun c:ChkMinArea (/ ss1 Limit a b c)
 (setq Limit 30000)
 (setq ss1 (ssget "x" '((0 . "LWPOLYLINE")(8 . "FinalTrim" ))))
 (setq a (entlast))
 (setq b (vla-get-area (vlax-ename->vla-object a)))
 (setq c ( - Limit b))
 (if (>= b Limit)
  (princ "\nArea is Okay... proceeding....")
  (Alert (strcat "Plate needs extending by\n" (rtos c) "mm2 Area"))
 (Princ)
);end defun
Test Upload.dwg
19 minutes ago, Sharper said:
Hi Guys
many thanks
 (setq Limit 30000)
 (setq a (entlast))
 (if (>= b Limit)
 (Princ)
);end defun
Edited by devitg
my error
you set ss1 using ssget but you are proccessing "a" by entlast. This is why it sometimes works and sometimes not, since the last entity is diffrent and errors out for wrong types
  • Thanks 1
The  Entlast , is the last entity made at the DWG, and NOT the last ent at the selection set
Ahh this makes sense
Staring me right in the face for the last 3 days...
Thank you guys, really appreciate the help
(setq ss1 (ssget "x" '((0 . "POLYLINE")(8 . "FinalTrim" ))))
   (setq ent (ssname ss1 0))
 (setq a ent)
  Test  it , as it is a only one "POLYLINE"
  • Thanks 1
i would go like this
(defun c:ChkMinArea (/ ss1 Limit i a b c)
  (setq Limit 30000)
  (setq ss1 (ssget "_X" '((0 . "POLYLINE")(8 . "FinalTrim"))))
  (setq i 0)
  (while (< i (sslength ss1))
    (setq a (ssname ss1 i))
    (if (>= b Limit)
        (command "_zoom" "_obj" a "")
    (setq i (1+ i))
  (Princ)
);end defun
  • Thanks 1
Hey EnM4st3r
I originally started off using sslength count, but removed it once i realised it would only ever be one closed rectangular shape on each file.
I suppose it wouldn't have hurt if i left it in there
My routine is now updated and working perfectly.
Thank you once again for the assistance
If only one entity at a time, you can add a Has-Property 'Area check.
(while (setq obj (vlax-ename->vla-object (car  (entsel "Pick obj for area "))))
(setq a (vlax-get obj 'Area))
(setq lay (vlax-get obj 'layer))
(alert (strcat "The Area is " (rtos a 2 2) " on layer " lay))
  • Thanks 1
