robierzo Posted March 29, 2024 Posted March 29, 2024 (edited) Hello. I have two sets (set1 and set2) with several elements. I need to create a new set (set3) with the repeated elements of both sets. Thank you Edited March 30, 2024 by robierzo Quote
Lee Mac Posted March 30, 2024 Posted March 30, 2024 https://www.lee-mac.com/listintersection.html 1 1 Quote
marko_ribar Posted March 30, 2024 Posted March 30, 2024 (edited) And how if you have 4 or more sets? Maybe like this : (defun MR:ListsIntersection ( ll / r l1 l2 ) (while (and (setq l1 (car ll)) (setq l2 (cadr ll))) (setq r (vl-remove-if-not '(lambda ( x ) (member x l2)) l1)) (setq ll (subst r l2 ll)) (setq ll (cdr ll)) ) r ) (MR:ListsIntersection '((1 3 5 2 4) (6 8 1 3 5) (9 0 1 3 5) (7 4 2 1 3) (1 3 5 7 9))) ;;; (1 3) M.R. Edited March 30, 2024 by marko_ribar 1 Quote
robierzo Posted March 30, 2024 Author Posted March 30, 2024 (edited) Hi Lee, hi Marco. I use google translator. Maybe I haven't explained myself well. I am referring to 2 selectionsets, S1 and S2, created using SSGET, for example. (setq S1 (ssget...)) (setq S2 (ssget...)) S3 would be formed by the common elements of S1 and S2. The solution you provide is valid. But I prefer a direct solution, without obtaining the lists of names beforehand. Thank you. Edited March 30, 2024 by robierzo Quote
marko_ribar Posted March 30, 2024 Posted March 30, 2024 (edited) Maybe like this : (defun c:sss-intersection ( / MR:ListsIntersection-sel-sets ss lst ) (defun MR:ListsIntersection-sel-sets ( ll / sel-set->ename-list ename-lists r l1 l2 rr k ) ;;; ll - list of sel.sets (defun sel-set->ename-list ( ss / i r ) (repeat (setq i (sslength ss)) (setq r (cons (ssname ss (setq i (1- i))) r)) ) r ) (setq ename-lists (mapcar (function (lambda ( x ) (sel-set->ename-list x))) ll)) (while (and (setq l1 (car ename-lists)) (setq l2 (cadr ename-lists))) (setq r (vl-remove-if-not '(lambda ( x ) (member x l2)) l1)) (setq ename-lists (subst r l2 ename-lists)) (setq ename-lists (cdr ename-lists)) ) (if r (progn (setq rr (ssadd) k -1) (repeat (length r) (ssadd (nth (setq k (1+ k)) r) rr) ) ) ) (if (and (= (type rr) (quote pickset)) (> (sslength rr) 0)) (sssetfirst nil rr) ) ) (prompt "\nChoose selections - when done press ENTER or right click...") (while (setq ss (ssget)) (setq lst (cons ss lst)) ) (MR:ListsIntersection-sel-sets lst) (princ) ) HTH. M.R. Edited March 31, 2024 by marko_ribar 1 Quote
mhupp Posted March 30, 2024 Posted March 30, 2024 (edited) i would just use On 3/30/2024 at 10:40 AM, robierzo said: I am referring to 2 selectionsets, S1 and S2, created using SSGET, for example. I would use ssmemb then. this will create a global selection set SS3 ;;----------------------------------------------------------------------------;; ;; Create a third selection set of values found in both selection sets provied ;; (ssint ss sss) (defun SSInt (SS1 SS2) (setq SS3 (ssadd)) ;create a blank selection set to add entitys to (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS1))) ;generate a list of entity names (if (ssmemb ent SS2) ;test if its in the other selection set (ssadd ent ss3) ;add to the 3rd selection set if true ) ) (princ) ) Edited April 1, 2024 by mhupp 1 Quote
Steven P Posted March 30, 2024 Posted March 30, 2024 Doesn't ssadd add the entity if it is not there else it ignores it - so not sure you need the(if (ssmemb.....) ? (weekend.... ) 1 1 Quote
mhupp Posted March 30, 2024 Posted March 30, 2024 (edited) I see what your saying could be condensed down to. bad code Quote Return Values If ename is a member of ss, ssmemb returns the entity name. If ename is not a member, ssmemb returns nil. Edited April 1, 2024 by mhupp 2 Quote
ymg3 Posted March 31, 2024 Posted March 31, 2024 (edited) @mhupp, You cannot do (ssadd nil ss3) you will get an " error: bad argument type: lentityp nil". So you need the if clause. ;;SSint by mhupp ;; ;; ;; ;; Return a selection set of Common element to both sets ;; ;; ;; (defun ssint (ss1 ss2 / e ss3) (setq ss3 (ssadd)) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss1))) (if (ssmemb e ss2) (ssadd e ss3)) ) ss3 ) Edited April 1, 2024 by ymg3 One too many ssmemb remove, name of author typo 2 Quote
mhupp Posted April 1, 2024 Posted April 1, 2024 k switched my first post. test ssmemb if true then do ssadd Quote
robierzo Posted April 1, 2024 Author Posted April 1, 2024 Thanks everyone for your help!!!! It works perfectly. Thank you!!!! Quote
