the closed polylines get new Z values from own center points.
macros55
Hi Everybody, I need a lisp,  the closed polylines get new Z values from own center points. Thanks.
(defun c:changeZ (/ c_lwp c_pt lista_coord ename n Z_pt obj_n)
  (prompt "\nSelect the polylines")
  (setvar 'nomutt 1)
  (setq c_lwp (ssget '((0 . "LWPOLYLINE"))))
  (setvar 'nomutt 0)
  (setq n 0)
  (repeat (sslength c_lwp)
    (setq lista_coord nil c_pt nil)
    (setq ename (ssname c_lwp n))
    (setq obj_n (vlax-ename->vla-object ename))
    (foreach el1 (entget ename)
      (if (= (car el1) 10) (setq lista_coord (cons (cdr el1) lista_coord)))
    (setq c_pt (ssget "_CP" lista_coord '((0 . "POINT"))));selecciona el punto
    (if c_pt
    (setq Z_pt (caddr (cdr (assoc 10 (entget (ssname c_pt 0))))));obtiene la Z
        (vla-put-Elevation obj_n Z_pt);cambia la elevación
    (setq n (1+ n))
Try this code
