How can I reduce my file size?
Hi guys this is my first thread here in forum i hope you guys can help me,
My problem is, I have a 2d file in cad, the file size is about 3mb, then i try to edit the file i delete all drawings after that i make a line on it in the same file, after i save the file... the file size is still the same... even if i purge it and audit it..
So what is really the problem?
Please best regards chilll
  • Replies 22
  • Cad64
    4
  • skipsophrenic
    3
  • chillrender
    3
  • Organic
    2
Why don't you just start a new drawing?
What you are doing is not a good habit. You should always start fresh with a new file. That way you don't get all the leftover junk from the previous drawing.
I have renamed your thread to something more descriptive and moved it to the Beginners Section.
Please take a minute and read our posting guidelines: http://www.cadtutor.net/forum/showthread.php?t=23105
Also, since I renamed your thread, you can now check the 'Similar Threads' at the bottom of this page. One of them specifically addresses the problem you have described.
Thanks for the quick reply sir, sorry for the wrong thread that i post, actually ill make the drawing from the scratch sir, but later when i move up, i noticed that the file is hung up, and then ill try to delete some of my drawings then the file sized is still remain, this is happen for that file only the rest is not, and ill try also cut and paste the file, with the new document, but the problem is still remain, so theres any tricks to fixed that one?
thanks
you can just type "purge" @ command line then pressing purge all in the window
type "purge" and purge all until you cant purge anymore
Also do a quick audit on the file. :)
she has already purged it & audited it, as mentioned by her in her first post above
:oops: sorry was skim-reading
I know what PURGE is, although what exactly is AUDIT?
This from AUTOCAD HELP (F1)
Audit : Evaluates the integrity of a drawing and corrects some errors :?
Did you read the 'Similar Threads' at the bottom of this page?
Yah read all similar threads and nothing works, i think it is a bug...
Try "aecexporttoautocad" removes proxy data makes files a lot smaller but be aware you may need the proxy data. Also try "wblock" this can give big reduction in file size.
Sometimes "registered applications" can be the cause. Remove them with the command line version of purge - "-purge" (include a hyphen).
I've never heard of this? :unsure:
Is this an Autocad command? When I type AecExportToAutoCAD, in Autocad 2007, I get "Unknown Command".
So you've done everything listed below?
Deleted everything from model space and paper space layouts
Hit Ctrl+A to Select any unseen entities and then hit Delete
Purge
-Purge Regapps
Audit
Delete Layer Filters
Detach Xrefs
Detach Images
And still the file size remains large? :unsure:
I say toss it and start with a fresh new file.
As I mentioned before, this is always the best approach.
How about WBLOCK and select the drawing...?:)
Or, Erase > All > and Remove (select the drawing content you want).
Theres sometimes blocks with just points, or no graphics which can be deleted and purged. Worth a try?
Youl could try a -purge, then R and also -scalelistedit to reset all your viewport scales. That will speed up and reduce the drawing file.
A thing that I just found because I couldn't understand how my file (with 7 Lines in it) could be 2500 kB while a file from the same project with the same purge/audit routines applied to it, but with little over 800 elements (lines, arcs, circles, texts) was around 400 kB.
I found that when I changed from fileformat 2000 to 2004, the file shrunk from 2500 kB down to 294 kB ... why? no clue.
