Spiderguy Posted March 10, 2009 Posted March 10, 2009 Hello, I was hoping that someone would be kind enough to download these 2 DWG files and convert them into IGS files. I would greatly appreciate it! Thanks! Matt Hamby PHONE BRACKET X 2.dwg PHONE SHELF.dwg Quote
SEANT Posted March 10, 2009 Posted March 10, 2009 Converted via AutoCAD Mechanical 2009. Iges.zip Quote
Spiderguy Posted March 12, 2009 Author Posted March 12, 2009 Thanks, I do appreciate it greately! Matt Quote
bhamarsd Posted May 11, 2009 Posted May 11, 2009 Hi.. I am trying to achieve the same translation. Unable to do so using Autocad 2008. Can you please describe the way you achieved this? thanks a lot !! Quote
SEANT Posted May 11, 2009 Posted May 11, 2009 Mechanical, one of the vertical products based on AutoCAD, comes with an IGES exporter. The feature is not available in vanilla AutoCAD. If it is a one-time translation, post it here. Enough of us have the vertical and will translate it for you. Quote
bhamarsd Posted May 11, 2009 Posted May 11, 2009 Thanks a lot I have attached 2 zip files. Unfortunately there size is huge compared to the limit here:( Can I get your email ID so that i can email you them? Thaking you again, Quote
SEANT Posted May 11, 2009 Posted May 11, 2009 From your User Control Panel, enable “Receive Email from Other Members”. Quote
bhamarsd Posted May 11, 2009 Posted May 11, 2009 HI.. I just made it on.. Thanks for your patience and help.. I appreciate it . Quote
GGreen Posted August 23, 2009 Posted August 23, 2009 Hi Seant, I have 2 .dwg files that I have been trying to convert to .iges, I have been looking for a converter online but cannot find anything. Would it be possible for you to please covert 2 files for me? Thank you very much Gus Quote
kencaz Posted August 23, 2009 Posted August 23, 2009 SEANT: your gonna have to start charging for this service...!!! KC Quote
SEANT Posted August 24, 2009 Posted August 24, 2009 SEANT: your gonna have to start charging for this service...!!! KC Hey, no doubt. Maybe when Mechanical fails to bring a return on investment in it's primary role. In the mean time, post the files and I'll see what I can do. Hi Seant, I have 2 .dwg files that I have been trying to convert to .iges, I have been looking for a converter online but cannot find anything. Would it be possible for you to please covert 2 files for me? Thank you very much Gus Quote
hfcowboy Posted October 30, 2009 Posted October 30, 2009 Seant, if you still don't mind converting files from dwg to igs, I have a couple I need converted. x_COMM_MOD1xxx.dwg x_IO_MODxxx.dwg I would really appreciate it and just to be clear is there nothing other than mechanical desktop (I was also told inventor) that will creat igs files? Quote
SEANT Posted November 1, 2009 Posted November 1, 2009 Actually, a lot of applications will handle IGES files. Vanilla AutoCAD, unfortunately, does not. x_COMM.zip x_IO.zip Quote
hfcowboy Posted November 2, 2009 Posted November 2, 2009 Thanks a bunch Seant! Really do appreciate it. Quote
behzadm18 Posted November 14, 2009 Posted November 14, 2009 Hello, I would be grateful if someone can convert the attached file from .dwg to .igs it will help me a lot. many thanks. final12deg.zip Quote
Coosbaylumber Posted November 14, 2009 Posted November 14, 2009 Actually, a lot of applications will handle IGES files. Vanilla AutoCAD, unfortunately, does not. I found the basic problem was at Initial loading of Autocad. As I remember, there are three choices. Tutorial or basic, Full, and Custom. If you choose Custom as I do often, then along the way it will ask what filters to load? IGES is just one of them. Cannot go back and load it in separately. Wm. Quote
SEANT Posted November 15, 2009 Posted November 15, 2009 If I recall correctly, igesin and igesout were available to AutoCAD 14, and maybe even 2000, but were dropped from standard AutoCAD after that (possibly as another incentive to promote vertical sales). I can’t confirm that, however. My last few install have been Mechanical, and that definitely has those commands available. With regard to this latest translation request, my system is incapable of processing that “zip” file. You will have to repost it. With regard to future translation requests (and only speaking for myself): I’ll only assist with a request from members with 10 or more posts (look back through this thread to understand the reasoning). I think if someone needs a favor they should be willing to hang around a while. Quote
Cad64 Posted November 15, 2009 Posted November 15, 2009 If I recall correctly, igesin and igesout were available to AutoCAD 14, and maybe even 2000, but were dropped from standard AutoCAD after that (possibly as another incentive to promote vertical sales). I can’t confirm that, however. My last few install have been Mechanical, and that definitely has those commands available. That is correct. The igesin/igesout function was removed from Autocad a long, long time ago. With regard to future translation requests (and only speaking for myself): I’ll only assist with a request from members with 10 or more posts (look back through this thread to understand the reasoning). I think if someone needs a favor they should be willing to hang around a while. Great idea. Quote
Thiago Bressani Posted January 11, 2012 Posted January 11, 2012 Hi Seant, Please, there is a possibility you convert a file .dwg to an IGES file? I've been trying without success. Thank you! Thiago Quote
