Convert DWG into IGS?
Hi Seant,
Please, there is a possibility you convert a file .dwg to an IGES file? I've been trying without success.
Thank you!
Thiago
With regard to future translation requests (and only speaking for myself): I’ll only assist with a request from members with 10 or more posts (look back through this thread to understand the reasoning). I think if someone needs a favor they should be willing to hang around a while.
I would be inclined to do the same. Browse the forum and provide 10 good answers to some questions.
  • Replies 29
  • SEANT
    7
  • Cad64
    3
  • bhamarsd
    3
  • Thiago Bressani
    3
That is correct. The igesin/igesout function was removed from Autocad a long, long time ago.
IGES translation was added back to vanilla AutoCAD 2012.
now export
AutoCAD 2012 will import a whole host of filetypes and export many more than it used to in 2011.
Also FREE Inventor Fusion will do translations http://labs.autodesk.com
Thanks JD mather.
I downloaded the Inventor Fusion and i'm still trying to do the translation.
I need the geometry in IGES extension, because I will put it in a fluid dynamic model.
Regards.
...i'm still trying to do the translation...
File>Save as (Save as type: (*.igs)
What problem are you experiencing?
The purpose of this translation is to use geometry in a computacional fluid dynamic model (Ansys Package). So, the Ansys don't recognize the drawing because the scale was too large to display.
I found the solution using Rhino.
Thanks a lot!!
What units did you have set?
Is the geometry is the geometry - but you have to have the correct units (size).
Can you convert these dwgs to igs?
thanks
[ATTACH]32431[/ATTACH][ATTACH]32430[/ATTACH]
Perhaps it's time to close this thread?
And cut off all this free labor? What are you, some sort of anarchist?
