How To Automate Grouping Shapefile Data into Blocks based on Object Data in AutoCAD
Satya
Hello everyone, can anyone help me, I have a case example that is almost similar to the actual case I am experiencing now. In the 1st picture I have a shapefile of the administrative boundaries of the United States that I have entered into autocad, the shp attribute has been entered into the data object of each feature with the data object name "GADM", in the data object there are State and County fields, for the layer of each feature I use the County field reference so that each feature is currently layered with its respective county name. what I want is that as in the 2nd picture I want each feature to be grouped or made per block per category of state, is there a quick way, because I think in each feature there is a State field?
Noted: The Autocad that I use is AutocadMap 2021.
Pic 1
Pic 2
