Hi,
We have a HP Laser printer in the office which plots out off order when you use the publish command. I have turned off background plotting/publishing. Every other printer has no issue with publish though :?. Is there something I can do about this? Thanks in advance.
I think PUBLISHCOLLATE will control that, see what it is set to and toggle, only choices are 0 and 1.
Tip, type PUB and hit tab three of four times while watching the command line, hit enter when the command shows.
I have publishcollate set to 0, since i publish to pdfs and plt files as well. the problem seems to be specific to a single printer so i thought there might be some option to buffer or spool (not sure which is right) on the pc rather than the printer.
