Ferronovum Posted March 12, 2009 Posted March 12, 2009 Since i ran into a problem with plotting 3D Hidden style with so far no solution, I have an idea for a Lisproutine. The routine is like this: 1 check four assigned layers 2 clear each assigned layer from any objects 3.1 move to dessired(coded) view 3.2 take the flatshot 3.3 insert the shot/block in assigned layer Repeat for all four views(front, left, back, right) 4 close/freeze the assigned layers in MS In a Layout you have four viewports only showing each assigned layer. Wolahhh Now you have 2D drawings of the 3D object. This routine should be easy to modify for more or less views and angels. Problem is this, I have this really great idea, but no idea at all how lisp works . I could probely learn lisp. I have coded alot C++ back in the days (6-10 years ago). But I need someone to help me get started. I got the Idea, YOU got the knowlegde of Lisp. Quote
Ferronovum Posted March 13, 2009 Author Posted March 13, 2009 Seams like many users are looking for a code like this cuz many views but none reply However, this is as far as I got with my knowlegde at the moment. Yes, I used to code in c and c++ can anyone translate it to lisp? ;; Flatshot routine taking shots in front/back/left/right view ;; Author: So far just me ;; by idea of: Björn Lindström ;; ;; Suggested structure: for (i=0, i<4, i++) Command:UCS Command:G if (i=0) Command:F if layer flatshot front doesn't exists create layer flatshot front set layer flatshot front clear layer from objects Command:PLAN Command:C Command:flatshot Command insert point:0,0,0 Command scale factor X:1 Command scale factor Y:1 Command rotation: 0 hide layer flatshot front set layer 0 if (i=1) Command:BA if layer flatshot back doesn't exists create layer flatshot back set layer flatshot back clear layer from objects Command:PLAN Command:C Command:flatshot Command insert point:0,0,0 Command scale factor X:1 Command scale factor Y:1 Command rotation: 0 hide layer flatshot back set layer 0 if (i=2) Command:R if layer flatshot right doesn't exists create layer flatshot right set layer flatshot right clear layer from objects Command:PLAN Command:C Command:flatshot Command insert point:0,0,0 Command scale factor X:1 Command scale factor Y:1 Command rotation: 0 hide layer flatshot right set layer 0 if (i=3) Command:L if layer flatshot left doesn't exists create layer flatshot left set layer flatshot left clear layer from objects Command:PLAN Command:C Command:flatshot Command insert point:0,0,0 Command scale factor X:1 Command scale factor Y:1 Command rotation: 0 hide layer flatshot left set layer 0 Quote
