MSasu Posted March 13, 2009 Posted March 13, 2009 Hello, I need for a current project to list the coordinates of “extended” area of a drawing (that it, the entire drawed area in Model Space) from VBA (accessing AutoCAD via ActiveX automation from a stand-alone application). Due to the fact that the drawing is a very loaded one, parsing entities to gather coordinates and sorting it wasn’t a solution since it last too much. So, my solution was to do a zoom / extend, create a view and list after the coordinates of his center and size; from this can calculate the coordinates of the bottom-left and top-right corners of view and therefore drawed area (of course, not necessarily accurate on one direction). Unfortunately the values listed as view features seem to don’t match the ones manually listed on screen. Dim theAcadApp, CrDrawing As Object Set theAcadApp = CreateObject("AutoCAD.Application") Set CrDrawing = theAcadApp.Documents.Open("...ARandomFile...") theAcadApp.ZoomExtents Dim theExtendView As Object Dim theCenter As Variant Dim theCornerBL(1) As Double Dim ViewWidth, ViewHeight As Double Set theExtendView = CrDrawing.Views.Add("NewView01") theCenter = theExtendView.Center ViewWidth = theExtendView.Width ViewHeight = theExtendView.Height theCornerBL(0) = theCenter(0) - 0.5 * ViewWidth theCornerBL(1) = theCenter(1) - 0.5 * ViewHeight Does someone know what I’m doing wrong? Or there is another, better, solution to solve my issue? Thank you! Regards, Mircea Quote
