brianhiroshi Posted April 23, 2009 Author Posted April 23, 2009 Well, as a matter of fact there is one thing I was trying to do but didn't manage to. After making the drawing and placing the dimensions, I tried to scale the whole thing, but I don't know how to pick the entities without having to use pickpoints (which was not very effective to select the dimensions) or window/crossing (which can end up selecting other entities that were not supposed to be selected). Later, I will have to rotate the drawing too, then I will come to the same problem with selecting the drawing. Would you have any idea of how to do it? Thanks! Quote
Lee Mac Posted April 23, 2009 Posted April 23, 2009 I'm not quite following you, are there entities you don't want to select very close to ones you do? Quote
brianhiroshi Posted April 23, 2009 Author Posted April 23, 2009 Sorry, my english is not very good. Basically yes, there may be a chance that the user of the routine will use it to draw over another drawing, then we would have lines drawn by the program and others by the user mixed. I wanted to scale only the lines and dimensions made by the lisp. Thanks Quote
Lee Mac Posted April 24, 2009 Posted April 24, 2009 If you are having line and entities drawn by a LISP, then the way I would proceed is to make the LISP create a global variable containing a list of entity names of all the entities created by the LISP. That way you could refer back to them at a later date. But, of course, this would only work for during the drawing session. The only other way I would think of would be to either create the LISP lines with their own colour or layer. Quote
brianhiroshi Posted April 24, 2009 Author Posted April 24, 2009 Yes, that's what I did. It was something like that... (command "._line" pt1 pt2 "") (setq e1 (entget (entlast))) . . . (setq entities (list e1 e2 e3 ...)) (command "._scale" entities "" pt1 scalenumber "") I've tried variations of this but neither of them worked. I don't know what I might be doing that it's not working. Thanks Quote
Lee Mac Posted April 24, 2009 Posted April 24, 2009 Scale requires a selection set, not a list of entities - I just suggested a list of entities, as I thought it may be easier to keep track of things. But use this: (setq ss (ssadd)) (command "._line" pt1 pt2 "") (ssadd (entlast) ss) . . . (command "._scale" ss "" pt1 scalenumber "") Quote
brianhiroshi Posted April 24, 2009 Author Posted April 24, 2009 It worked perfectley, thank you very much Lee Mac, I've been working in this the whole week, sorry for all the trouble. Thanks again Quote
Lee Mac Posted April 24, 2009 Posted April 24, 2009 Glad it worked for you Sorry to have misled you slightly with the entity list. Quote
