VBA SaveAS Run-time error '-2145320861...
I have the following code:
'GENERATING A SPECIFIC NAME FOR THE DRAWING AND SAVE IT
xtNumPed = Format(txtNumPed, "00000#")
sNP = Right(txtNumPed, 6) 'os seis últimos d�*gitos do nº do pedido
dHr = Format(Hour(Now), "0#") 'hora
dMn = Format(Minute(Now), "0#") 'minuto
dSc = Format(Second(Now), "0#") 'segundo
txtNDES = "RED" & "-" & sNP & "-" & dHr & dMn & "-" & dSc
sNDes = txtNDES 'nº do desenho
Dim SavePath As String
Dim SaveName As String
SavePath = "\\main\trabalho\autocad\automation\"
SaveName = SavePath & sNDes & ".dwg"
ThisDrawing.SaveAs SaveName, acNative
'THE CODE ABOVE GENERATES THIS MESSAGE:
"Run-time error '-2145320861 (80210063)': Error saving the document"
I'd like to receive information about this error.
Thanks!
  • 2 weeks later...
I am having the exact same problem.
Could you say which AutoCAD version you are using, and what the OS is?
I'm using 2005, and Windows Server 2003.
  • 3 years later...
Has this issue been resolved yet? I am having identical problems to what is being reported here and have found no help at all.
I am automating AutoCAD 2012 via scripting from VB6. I am currently using AutoCAD 2012 on an up to date Windows XP machine that is running as a Virtual Machine.
If I just run straight through, this code fails quite often. If I stop in the d e b u g g e r and slowly single step through the sub that the code is in, it will usually do what is needed. If it does fail while single stepping and I resume next and then set the line that does the SaveAs as the current line of execution and retry it, it works most of the time. This seems to be some kind of timing issue or something but for the life of me, I can't come up with an answer.
I also get the following useless dialog box a lot when these issues come up. As you can plainly see, this error dialog is of absolutely no use at all.
If any of you have come up with an answer or work-around for this, I would really appreciate a reply here or an email.
Thank you in advance for any help on this issue.
Pat
Edited by PatrickMoe
modify censored word
:facepalm:I had to post one more to laugh at the fact that the word d e b u g g e r got censored.
