sw33ney Posted March 16, 2009 Posted March 16, 2009 Hi all i have created blocks to insert on top of hatch's although once inserted it is as if the hatch is transparent as i can see the hatching through the block can help please thanks again. S Quote
Came Posted March 16, 2009 Posted March 16, 2009 something like this http://discussion.autodesk.com/forums/message.jspa?messageID=6056064 it could help hope, tray it Hope someone could clear this one. Quote
Lee Mac Posted March 16, 2009 Posted March 16, 2009 I suppose you could use WIPEOUT, but probably not the best solution. Quote
sw33ney Posted March 16, 2009 Author Posted March 16, 2009 i sorted it out, easily by just drawing the blocks first and then hatching around them:oops: :oops: thanks lol Quote
Came Posted March 16, 2009 Posted March 16, 2009 if you come across some tool to fix it let us-me now SORRY about that one Quote
Came Posted March 16, 2009 Posted March 16, 2009 Well you can do that let as now if you find some way to fix it without drawing again. It would be nice SORRY about that one Quote
lpseifert Posted March 16, 2009 Posted March 16, 2009 Did you try trimming the hatch using the block's entities as the trim edges? Quote
Lee Mac Posted March 16, 2009 Posted March 16, 2009 ^^ sometimes the simplest solutions are the best Quote
Krztoff Posted March 19, 2009 Posted March 19, 2009 Don't know if i understood your problem correctly, but if you want to have a block on top of a hatch, and not to see the hatch nderneath, you can always use "bedit" command and edit the block by putting a white solid fill underneath all the other block components, this way, when you print the drawing on white paper it will seem that you don't have any hatch undeneath the block, but in reality there will be, this will not affect the hatch AREA properties in case you need to preserve them. A very primitive solution, but it comes in handy when I ned to put up road signs in my drawings Quote
