I have a template file with one layout. I need two page setups named “Full Size ANSID to pdf” and “Half Size ANSIC to pdf”. I need Plot area should always be “Layout”, not to use “window.” The “Half size” set-up should print from the same paper space as the full size, but to a different paper size and changes the scale by ½.
Can anyone help on this?
You just need to add or import a page setup I think from the page setup dialog.....I think :D
How do you export a page setup? Was trying to figure it our the other day.
Also how do you import/export a print setup?
It always good to learn new tips :lol:
THANKS wannabe
we learn some thing every day :P
You can use the PAGESETUP command to import page setups. The topic is covered in AutoCAD Help. The Import button is on the right hand side of the Page Setup Manager dialog box.
