Dahzee Posted May 13, 2024 Posted May 13, 2024 This might seem a bit random and I have looked to see if this has been asked before. Â I would like to create a line on a specific layer, sometimes horizontal and sometimes vertical (it will always be one or the other) that extends left/right or top/bottom to the nearest entities. Â The idea of this is I have a CNC cutting machine that I want to break up the waste material to a smaller size, so adding extra lines in, cuts the material so the pieces are small enough to throw away rather than having a rectangle of material (cardboard in this case) which I then have to tear up to throw away. Â I presume the routine would go something like this: Â Start the command and it asks you if you want a horizontal or vertical line (preferably remembering the last option). Â Once you have chosen V or H you are then asked for a point. This almost always isn't a SNAP point so doesn't need a particular SNAP setting. Â A point is chosen and a line is created that extends to the nearest entities in both directions which would be either lines, arcs, circles or polylines. Â I created a video that almost shows what I mean (I cheated and added a small line in first ) which I then extended in both directions at the same time. Â Hopefully, the explanation and video make enough sense for it to be understood. Horizontal and Vertical to Entities.mp4 Quote
pkenewell Posted May 13, 2024 Posted May 13, 2024 (edited) Try this - no need to Select H or V just pick the points in a H or V direction (or at any other angle you want): (defun c:ELINE (/ p1 p2) (while (and (setq p1 (getpoint "\nSelect 1st point of Line: ")) (setq p2 (getpoint p1 "\NSelect 2nd point to define angle: ")) ) (progn (command "._line" "_non" p1 "_non" p2 "") (Command "._extend" "" p1 p2 "") ) ) ) I like this - I think I am going to keep this for my library since it is so simple. Â P.S. Let me know if you would prefer to have a special layer set or created and I can easily add that. Edited May 13, 2024 by pkenewell Quote
Dahzee Posted May 13, 2024 Author Posted May 13, 2024 @pkenewell Thanks for this it works even easier than I imagined. Â What would I need to add to make the lines on a specific layer and then change back to the current layer? Â As the layer used for these types of lines is only ever used for this purpose, so once I have finished adding them I need to go back to my current layer. Â Sorry, I don't want to sound ungrateful as your routine does do what I asked Quote
pkenewell Posted May 13, 2024 Posted May 13, 2024 (edited) Here you go. Set the variables mlayer, mlt, and mcol to your preferences: (defun c:ELINE (/ *error* cla mcol mlayer mlt p1 p2) (defun *error* (msg) (princ msg) (if cla (setvar "clayer" cla)) (if cmo (setvar "cmdecho" cmo)) ) (setq mlayer "ELINE_LAYER" mlt "CONTINUOUS" mcol 9) (command "._undo" "_be") (Setq cla (getvar "clayer") cmo (getvar "cmdecho")) (setvar "cmdecho" 0) (if (not (tblsearch "LAYER" mlayer)) (command "._layer" "_m" mlayer "_L" mlt "" "_C" mcol "" "") (setvar "clayer" mlayer) ) (while (and (setq p1 (getpoint "\nSelect 1st point of Line: ")) (setq p2 (getpoint p1 "\NSelect 2nd point to define angle: ")) ) (progn (command "._line" "_non" p1 "_non" p2 "") (Command "._extend" "" p1 p2 "") ) ) (setvar "clayer" cla) (command "._undo" "_E") (setvar "cmdecho" cmo) (princ) ) Note - I also added some basic error handling and an UNDO group. Â EDIT: Updated again to turn off command echoing. Edited May 13, 2024 by pkenewell Quote
Dahzee Posted May 13, 2024 Author Posted May 13, 2024 Absolutely perfect! Â Thank you very much for your help. 1 Quote
BIGAL Posted May 14, 2024 Posted May 14, 2024 pkenewell nice idea very simple. Â Dahzee dont forget press F8 will force a H or V. F8 off / on etc. Â 1 Quote
