Kawlos Posted May 13, 2024 Posted May 13, 2024 Hello! I've been tasked with trying to get some LISP routines working with Ares Commander. To be honest, I've had to write everything from scratch with limited to no experience, so do bear with me. Working in Surveying, we have three buttons for scales to text in the model space: 50, 100 and 200. Each button creates a global scale and changes the LT Scale, PDsize and of course, the text based on what you click. The Global Scales are: 1:50 - 0.004 1:100 - 0.008 1:200 - 0.012 Our main text sizes are fine: 1:50 is .1, 1:100 is .2 and 1:200 is .3. So in our text lisp routine, it's as simple as * 25: ;; Set the text height based on global scale factor (setq txtHeight (* 25 globalScaleFactor)) ; Calculate text height based on global scale (setvar "TEXTSIZE" txtHeight) ; Set the global text height But when it comes to a different text lisp for annotations, I need to get the text height to equal the following: 1:50 - .2 1:100 - .3 1:200 - .4 Now this isn't as simple as * 25 as it doesn't work, so instead, the entire lisp routine is the attached, but for some reason I cannot get it to work. I'm just wondering if anyone can make any suggestions to get me past the line! I've attached an example of T2 which works fine, and T3 which is what I need to work. If anyone needs the additional files to help, I can DM them to you. T2.lsp T3test.lsp Quote
